Old 03-30-2017, 09:54 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Aftermarket radiator
Looking for some input on aftermarket radiator for my 70 Camaro with LSA engine, auto trans. I'm planning on using the stock radiator support, which GM designed so the radiator sits on the bottom of the support. Planning on doing something with dual fans and both inlet and outlet on right side...... Any suggestions on the "best set-up?
The Following User Says Thank You to DKz Garage For This Useful Post:
scdarcy (09-24-2021)
Old 03-30-2017, 06:47 PM
patriot68 patriot68 is offline
Entropy radiators
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - @her_name_is_celeste - Speedtech Extreme Subframe/Torque Arm, LS3/4L60E, 19x12/18x10 Budniks
Old 03-31-2017, 05:33 AM
nicks67ca nicks67ca is offline
Entropy
Afco
Griffin
SUPERIOR RADIATOR
C&R
Frostbite (holley)
All have ls swap radiators. Tons of info on them as well.
I am not sure which of the above I'm going with for my LSA swap. I'm leaning towards Superior or Afco.
Fan kits, wiring kits (some with PWM options) all come into play as well.
Old 03-31-2017, 02:51 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
We pretty much use Be Cool exclusively.
They're really nice.
They're a little more expensive than some, but super high quality.
Let me know if you need a quote.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 03-31-2017, 07:38 PM
carbuff's Avatar
carbuff carbuff is offline
What are you going to do with the car? Street cruiser? Autocross? HPDE / Track Days? And in what climate?
Questions to ponder to make sure you end up with the right cooling system...
Old 04-02-2017, 05:41 AM
AutoRad.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 04-02-2017, 07:17 AM
Oleyellar Oleyellar is offline
Whaat? Nobody listed Ron Davis Radiators.
http://www.rondavisradiators.com
Old 02-27-2019, 06:10 PM
NickBurns NickBurns is offline
Ron Davis? I never heard of these guys? I was leaning towards Autorad for my LSA swap in the first gen
Nick's son was last seen finishing up his 1968 Pro Touring Camaro
1968 Pro touring Camaro
ALL DSE Suspension
2017 6.2L made of steel balls
Old 03-02-2019, 12:28 PM
572Camaro's Avatar
572Camaro 572Camaro is offline
Be Cool. Period
Old 03-02-2019, 12:51 PM
jmac jmac is offline
C&R or Autorad.
Had a BeCool in my Chevelle. Took 3 times for them to get it right. Every one of them were warped and not square. You placed it on the ground flat and it would wobble like a table with uneven feet. Wouldn't sit flush on the core support. Eventually swapped it for a Ron Davis piece. Was nice.
