Old 11-30-2021, 09:27 AM
jmac jmac is offline
Because the LT5 ECM is looking for a clutch switch and I’m adding Cruise control I added a clutch switch also while I was making stuff.
My disclaimer. This works for me and there maybe other ways to do it. I have used this system on the last 5 Camaros with zero issues. I then to revert back to “what do GM do” for a lot of my solutions.
It is amazing the the 1969 clutch pedal and the 1991 pedal are the same length. These setup coupled with a Centerforce clutch make the clutch pedal feel like a stock Camaro.
Hi Mark,
Quick question, the additional switch you added to the clutch pedal, is that just like a brake light switch? I'm looking to add this to mine as well.
Thanks!
John
My 1967 Camaro
Old 11-30-2021, 05:37 PM
joeko23 joeko23 is offline
That’s exactly a brake light switch. I also added this switch to my clutch in my 69 Camaro because I installed a push button start and didn’t want the car to start in gear.
https://www.ebay.com/itm/BRAND-NEW-B...-127632-2357-0
My Very Ambitious 69 Camaro Build
https://www.pro-touring.com/threads/...d-0-Fab-Skills
Old 12-01-2021, 02:26 AM
srode1 srode1 is offline
The stock pedals have a clutch safety switch, but they look for the clutch all the way depressed to start. This one is set up as the top of clutch switch which senses when you just start to get the clutch moving down, not disengaged yet. What's not clear to me is what brakelight switch he used since the ECM is looking for an open signal for top of clutch to defuel, and most brakelight switches are normally open and actuation closes the circuit. Maybe he used a relay to change the signal to the ECM. One switch I found that will work is ACDELCO D862C, it has 2 sets of contacts, one for normally open and one for normally closed. From the installation instructions:
The calibration included in the ECM is for a manual transmission application. The pair of wires labeled top of travel clutch switch must be wired used. This should not be used as a bottom of travel clutch switch or neutral safety clutch switch - do not use as a switch to prevent starter engagement without fully depressing the clutch. The top of clutch switch is used as in input to the ECM to briefly disable fuel when the clutch is depressed, which helps decelerate the engine and makes upshifting easier and quicker. A compatible clutch switch will have two pins which provide a closed circuit when the clutch pedal is fully released and an open circuit as soon as the clutch pedal is partially depressed.
The Following User Says Thank You to srode1 For This Useful Post:
jmac (12-01-2021)
Old 12-01-2021, 03:06 PM
I did not know that the ECM for the LT5 required that signal. I thought Mark was using that clutch switch just for the Dakota Digital cruise control to be able to disengage cruise mode when depressed.
I spoke to Dakota Digital today and they said all I need is another brake switch.
I'm sure Mark will chime in and let us know how he got that signal the LT5 ECM required.
My 1967 Camaro
Old 12-02-2021, 07:24 AM
Stielow's Avatar
Stielow Stielow is offline
The LT4 and LT5 have a top of travel input in the harness. I used an older style brake switch that have two sets of contacts. One sets of normally open and one set normally closed. I think it was from a 2nd gen Camaro with cruise.
Something like this:
https://www.amazon.com/Standard-Moto...a-843401827852
https://www.summitracing.com/parts/p...caAoUdEALw_wcB
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (12-02-2021), fleet (12-02-2021), jmac (12-07-2021)
Old 12-07-2021, 07:47 AM
andrewb70's Avatar
What exactly does the input do?
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
Old 12-07-2021, 08:43 AM
dhutton dhutton is offline
Andrew
fleet (12-11-2021)
