Old 05-25-2022, 09:02 AM
Perry Mitchell Perry Mitchell is offline
Years ago, I purchased the mounting cage from DSE to mount the Vintage Air unit under the dash on my '67. Fit perfectly with no holes in the firewall.
Old 05-25-2022, 09:20 AM
billohio billohio is offline
Thank you. I wouldn't think under the dash would be much different in years
Old 05-25-2022, 10:06 AM
thedugan's Avatar
thedugan thedugan is offline
Position it where you want it and weld studs to the inner firewall before you finish and paint the engine bay side.
Getting nuts on the top studs and tightening is pain and takes time. Least was for me.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 05-25-2022, 09:52 PM
randy randy is offline
I did the same.
Old 06-12-2022, 07:27 AM
I looked into thus a bit more. Guy at DSE told me under the dash is different on a 69 and their frame wouldn't work. Surely it could be modified but they are out of stock. The good thing I did, the holes are still in the original firewall so I know where studs would need to go. I trimmed some of the lip off but left the holes!
I am going to try elevator bolts and see if I can use the.
The Following User Says Thank You to billohio For This Useful Post:
camcojb (06-12-2022)
Old 06-12-2022, 07:19 PM
colorado80439 colorado80439 is offline
I have a DSE vintage air bracket I'm willing to sell, it was prefitted to the car and one of the mounting brackets may have been slightly modified. Make me an offer if you're interested
Old 06-13-2022, 12:58 PM
patriot68 patriot68 is offline
my firewall was smoothed and painted. I used weld mount adhesive and studs. Its been fine since 2010
https://www.jamestowndistributors.co...stening-system
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 06-16-2022, 07:32 AM
srode1 srode1 is offline
Bought one 3 weeks ago - wish I had known I would have taken it then. Very easy to install - works great.
