  #26
Old 06-08-2022, 05:31 PM
dhutton dhutton is offline
I have had similar issues related to the BIM. You can go into the BIM settings and change the bus address of the BIM. I’ve solved a couple of strange issues changing the address. There is four address options if I remember right.
Having the BIM and a scanner connected at the same time can also cause some strange things to happen depending on the style of Y connector you use on the port.
camcojb (06-08-2022)
