Old 01-26-2023, 11:29 AM
Goosesdad's Avatar
Started the passenger side. Had to lower the mechanism. I'm using 69' Camaro mechanisms with the Lokar cable pull and the Ringbros lever. Steve Lenning (Carbon Camaro) gave me the mechanisms about a million years ago!
Had to open up the inner door structure in a few places to make room for the cable and mechanism so I added a few reinforcements so the door pull would still be solid.
Also ran the cable through a couple little setups of a teflon bushing anchored with an Adel clamp.
The Lokar cable pull comes with a pulley. It all comes together very well and is a solid and super smooth open.
Now the fun begins, foam and fiberglass! The MDF ring is just a spacer to space out the door panel to make room for the speaker and speaker grill. Will make sense in later pics.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
camcojb (01-26-2023)
