Old 04-12-2023, 09:07 AM
syborg tt's Avatar
syborg tt syborg tt is online now
The first question is what is your budget and time line as swapping a subframe under takes time.
DSE, RideTech, QA1 and SpeedTech all sell bolt on kits which is more then 95% of most people's need or can actually use to it's potential. Personal I would stick with a true bolt on kit as you will be able to do 90% of the kits in a week or less.
marty-mj
130fe (04-12-2023)
Old 04-18-2023, 03:54 AM
srode1 srode1 is offline
If you are building a dedicated car from scratch and really want top performance for autoX Speed Tech Extreme with the torque arm is a great choice, room for really big tires up front. DSE with their 4 link would be my second choice, a bit less room for tires up front but a great package. That's my opinion, worth about $0.25
Old 04-18-2023, 05:13 AM
CHJNCSU CHJNCSU is offline
Thank you for the advice!
Old 07-28-2023, 09:03 PM
David Pozzi's Avatar
You definitely need an aftermarket subframe on a First Gen Camaro. You can't fit a decent size front tire under stock fenders with a factory subframe. DSE & Speed Tech, are good. I'm using the Art Morrison and find it easy to tune/work around. The DSE rear suspension on a first gen uses short shocks so there's not much room to lower the rear below their design height. Their second gen setup is better.
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
camcojb (07-29-2023)
