Old 07-28-2023, 10:03 PM
David Pozzi's Avatar
You definitely need an aftermarket subframe on a First Gen Camaro. You can't fit a decent size front tire under stock fenders with a factory subframe. DSE & Speed Tech, are good. I'm using the Art Morrison and find it easy to tune/work around. The DSE rear suspension on a first gen uses short shocks so there's not much room to lower the rear below their design height. Their second gen setup is better.
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
camcojb (07-29-2023)
