Old 09-25-2023, 11:32 PM
TechNova TechNova is offline
Default Iphone to car speakers
I don't want to run a conventional radio, gauges will occupy that spot for better legroom.
Is there a Bluetooth driver that will receive the Bluetooth signal from the phone
and send to conventionally wired speakers?
I am aware of Bluetooth speakers, have one in my shop don't want that in the car.
I want a conventional 6x9 dual mount in the package tray. It would also be cleaner to power a driver under the dash and regular speaker wires to the rear without the need for power in the rear.
And, it must pair automatically to the phone I set it up with, my shop speaker has to be manually repaired every time I go out of range.
Pre-pairing a couple phones would be a bonus feature.
Old 09-26-2023, 12:31 AM
Gambit's Avatar
Gambit Gambit is offline
I’ve used this JL audio receiver for my Camaro. Went this was as here (Oz) we can’t use the phone while driving. Figured with the buttons I can hook it up & control as I want.
https://www.jlaudio.com/products/mbt...receiver-91369
They do have this option without the buttons in a smaller size. Mine is just paired to the amp under the parcel shelf then to the 4 speakers.
https://www.jlaudio.com.au/product/m...ooth-receiver/
Dunno if anything like this is something like you’re after.
69 Camaro, LS1, T56, HTV2300, Brembos, Forgeline
As close to finished as it’ll ever be..
The Following User Says Thank You to Gambit For This Useful Post:
camcojb (09-26-2023)
Old 09-26-2023, 06:40 AM
I like the second one, use it to run and amp like this?
https://www.crutchfield.com/p_110JA2B/Jensen-JA2B.html
the first one has small buttons, I would hide it where the ashtray is, I think to would be hard to access, negating the advantage of the buttons.
The Following User Says Thank You to TechNova For This Useful Post:
Old 09-26-2023, 02:33 PM
Gambit's Avatar
Something like that should be fine I’d imagine. I’m just using an old Alpine 4 channel amp.
I agree, I prefer the smaller option but to make it street legal I went the other way.
Good luck with it!
camcojb (10-01-2023)
Old 10-01-2023, 07:18 AM
Default Bluetooth speaker..
Not sure how important 4 way sound ect are to you ..
But far simplest solution is a nice blue tooth speaker portable 0 install and sound quality is more than enough for me..
https://www.amazon.com/JBL-Boombox-B...0-5ec63b24bcb5
Far less expensive options also available
The Following User Says Thank You to XLexusTech For This Useful Post:
Old 10-03-2023, 07:38 PM
I want 6x9 in stock location in rear shelf. I have no interest in extra clutter sitting in the car. I have similar to what you showed on my toolbox, not what I want for this car.
Old 12-05-2023, 01:55 AM
Gambit's Avatar
Just to give you an idea on how it sits in my car. Isn’t huge but also not hidden. The other one if it works like mine (just without buttons) would be great. To the right of the column next to the vintage air controller.
The Following 2 Users Say Thank You to Gambit For This Useful Post:
camcojb (12-05-2023), dhutton (12-05-2023)
Old 12-05-2023, 06:54 AM
ilikeike's Avatar
ilikeike ilikeike is offline
I put one of these in my trunk next to my amp.
Works fine.
https://www.jlaudio.com/products/mbt...receiver-91126
This small amp runs all the speakers in my car. Nothing fancy, just tunes for the rare occasion, normally, I prefer to listen to the engine sound.
https://www.jlaudio.com/products/xd6...plifiers-98605
The Following 2 Users Say Thank You to ilikeike For This Useful Post:
camcojb (12-05-2023), Gambit (12-06-2023)
Old 12-06-2023, 05:40 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I've run one of the JLAudio MBT units also, easy to operate and sounded great.
The way mine was wired, you did have to turn it on each time but it paired on it's own.
Look in the marine and off-road utv listings, lots of brands and options for bluetooth receivers.
Jeff-
The Following 2 Users Say Thank You to Ketzer For This Useful Post:
camcojb (12-06-2023), Gambit (12-06-2023)
Old 01-05-2024, 02:48 PM
I did a bench test last week and was happy so I installed a Bluetooth amp and my rear 6x9 speakers.
1 amp, 2 speakers and some wire was all I needed. No seperate Bluetoogh adaptor.
The Pyle amp pairs to my phone automatically in a few seconds. It wasn't very loud until I adjusted the Bluetooth settings in the phone from earphone to speaker.
I am working on a way to hold the phone without drilling holes in my dash or bezel.
camcojb (01-06-2024)
