Old 03-08-2024, 06:07 AM
thedugan's Avatar
thedugan thedugan is offline
Jeeze, LS9 short blocks are worth big bucks these days....
https://sdparts.com/i-24507973-chevr...ong-block.html
I hope it's just a typo where the 9 key was sticking.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following 2 Users Say Thank You to thedugan For This Useful Post:
130fe (03-11-2024), camcojb (03-08-2024)
Old 03-08-2024, 07:38 AM
samckitt's Avatar
samckitt samckitt is offline
$100,000! Can't be right.
Pace Performance has it for $13,556.xx
https://paceperformance.com/i-622022...ance-6-2l.html
Why do you only get 6 ignition coils?
Scot
86 Monte SS
LS2/T56 Magnum
The Following User Says Thank You to samckitt For This Useful Post:
Old 03-08-2024, 07:51 AM
I'd guess they have the three coils already mounted to the covers in engine assembly. They leave out the far left coil as it covers a valve cover bolt, the others don't. They throw the other two coils in a box. Kinda lazy but I get it lol.
samckitt (03-08-2024)
Old 03-09-2024, 02:33 AM
srode1 srode1 is offline
As far as fitment the LT4 high pressure pump will mean you probably need to modify the firewall for clearance, for the pump and the electrical connections. That's the price of direct injection vs port injection. I'm sure you've read the other technical differences and that the LT4 has more torque earlier making for a flatter power curve too which is an advantage in any application IMHO. The wiring on the LT4 isn't really complicated, just plug stuff in and it works and it's gone in lots of cars so there's plenty of information on front runners.
The Following 2 Users Say Thank You to srode1 For This Useful Post:
camcojb (03-09-2024), fleet (03-18-2024)
Old 03-21-2024, 09:40 AM
colorado80439 colorado80439 is offline
Thanks for the insight, I've enjoyed watching your build
The Following User Says Thank You to colorado80439 For This Useful Post:
camcojb (03-21-2024)
Old 03-18-2024, 06:49 PM
rpol78 rpol78 is offline
My understanding is you have more ECM options with the LS and more options for making changes. I do like the LT4/LT5 engine with the direct injection. It just depends on what you want to do in the future.
Hmmm... Makes me wonder what my LS 396 engine is worth (LS9 block/LS9 CNC heads, Callies Magnum custom crank, Callies Ultra rods, JE custom pistons, Kong 2650).
FWIW - This is going in a '67 Chevelle.
The Following User Says Thank You to rpol78 For This Useful Post:
camcojb (03-18-2024)
Old 03-21-2024, 09:48 AM
Thumbs up
Very nice, Kong 2650 LSA blower on an LS9, with a dedicated SC pulley who's front runner is that?
Old 03-21-2024, 07:42 PM
Thx, It's the GM modified LSA accessory drive 19417908. It has the same spacing as the corvette accessory drive with the LSA SC pieces added to it. Unfortunately it doesn't look like it's available as a kit any more.
I ended up having to use the Holley A/C compressor mount with a Sanden SD7B10 since I couldn't get a GM compressor to clear the main cross member. I'm still trying to work out the A/C lines on it.
The Following 2 Users Say Thank You to rpol78 For This Useful Post:
camcojb (03-21-2024), fleet (03-22-2024)
Old 03-24-2024, 06:29 PM
Ended up going this direction
camcojb (03-24-2024)
