Old 04-13-2024, 06:22 AM
68454RS's Avatar
68454RS 68454RS is offline
Default Cross Ram tuning, where to start?
I picked up this old Edelbrock X-C8 crossram and i'm looking for advice on carbs. Holley recommends the 450 tunnel ram carbs but others have said to go with the 600's. Any of y'all ever set one up and get it tuned good?
It's going on a mild SBC 383 stroker, 401hp @ 5200 rpm 437tq @ 4200 rpm 5500 rpm rev limiter
The Following User Says Thank You to 68454RS For This Useful Post:
camcojb (04-13-2024)
Old 04-13-2024, 08:41 AM
The manifolds look cool, but were not the best performing setups. Seemed to work good at WOT. I would be thinking a pair of 390's or 450's max on a mild small block that's a street car.
68454RS (04-15-2024)
Old 04-15-2024, 05:43 AM
68454RS's Avatar
Yeah, That's about all i've heard is that these are not good for performance. I am going for the cool factor but still need to be driveable.
camcojb (04-15-2024)
Old 04-17-2024, 08:23 AM
bk2life bk2life is offline
Originally Posted by 68454RS View Post
Yeah, That's about.
pick whatever carbs you want, and a vacuum gauge and get to tunin..
cant be any harder than a 'normal' tunnel ram or any dual carb intake really.
you might have to get one of those cones that go over each carb so you can get them balanced
but any tunnel ram, or dual carb rig ive had, i just tweak each carb a little by little and then readjust idle on each.
its really not that hard, and even easier if you have a nice smooth not lumpy cam
The Following User Says Thank You to bk2life For This Useful Post:
camcojb (04-17-2024)
Old 06-29-2024, 07:20 AM
68454RS's Avatar
I set it up with a pair of QFT 450's. Had the vac advance and pcv hooked up from both carbs to a "T" then to the dist and pcv... it didn't like it. I removed all the vacuum stuff, removed the vacuum advance from the dist, locked out the mechanical advance, set the timing at 32 degrees, and now she seems to be happy and snappy.
Still need to build some stainless braid fuel lines
https://youtu.be/XHno2DRU5M4
The Following 2 Users Say Thank You to 68454RS For This Useful Post:
camcojb (06-29-2024), fleet (06-29-2024)
Old 06-29-2024, 07:22 AM
68454RS's Avatar
I built a manometer based on a video from Unity MotorSports Garage you tube channel. I'm going to see if I can get these balanced with my home made carb tool.
