Closed Thread
Old 08-14-2024, 07:28 AM
Stielow's Avatar
Stielow Stielow is offline
Default Hobbs Camaro (Old Drag Car)
Originally Posted by BonzoHansen View Post
Curious why G body - are the bases better suited for 1st gens? Like a better angle, etc.
https://www.ebay.com/itm/38719416483...mis&media=COPY
They bolt on with studs (more solid) and have a slightly longer neck.
Stielow Engineering
The Following 5 Users Say Thank You to Stielow For This Useful Post:
214Chevy (08-15-2024), BonzoHansen (08-14-2024), camcojb (08-14-2024), dhutton (08-14-2024), Ketzer (08-15-2024)
Old 08-16-2024, 07:34 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Mark, are these mirrors direct replacement for 68-69 camaro mirrors?
72 Camaro RS:SOLD
68 Camaro:
The Following User Says Thank You to 72Z/28 For This Useful Post:
camcojb (08-16-2024)
Old 08-16-2024, 08:13 AM
Stielow's Avatar
Define direct replacement. It is not a direct replacement. Some assembly required.
Stielow Engineering
Old 08-16-2024, 08:13 PM
72Z/28's Avatar
Thanks for the reply. I mean if the base of the G Body mirror and the stud spacing match with the 68 camaro mirror base, so there is no need to drill holes at different locations to fix the G Body mirror.
72 Camaro RS:SOLD
68 Camaro:
Old 08-18-2024, 05:05 AM
Stielow's Avatar
Yes you need to drill two holes and sort out what to do with the remote mirror control on the drivers side.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
72Z/28 (08-18-2024), camcojb (08-18-2024)
Closed Thread
