Old 04-24-2020, 04:48 AM
Stielow's Avatar
Stielow Stielow is offline
Default Camaro LT5
Originally Posted by jmac View Post
No mods to the T56? Are you running the Super Magnum?
I had D&D Performance tuned up my T56 Magnum. Their shop is 5 miles from my house and they are great to deal with.
Off memory replaced all the nylon sliders with brass and added better synchronizers where needed.
I also have 6th gear swapped to a 0.5 ratio to make cruising on the highway at 80 mph at around 1840 rpm.
Stielow Engineering
Old 05-10-2020, 05:46 AM
Mark,
What website is the speed calculator on? I couldn't find it. Yes I did look before bothering you LOL
thanks,
Jim
Old 05-10-2020, 06:28 AM
Stielow's Avatar
Originally Posted by Jimbo1367 View Post
Mark,
thanks,
Jim
It is an app from TREMEC. It is on my phone
Stielow Engineering
Old 05-11-2020, 09:10 AM
CarlC CarlC is offline
The Tremec app is great but be sure to remove the protective case on the phone or else false angle readings can occur.
http:www.vaporworx.com
Old 05-11-2020, 05:23 PM
130fe 130fe is offline
Anyone ever use the Spicer app? Like if you want to use an angle gauge instead of your phone?
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 05-11-2020, 07:46 PM
BonzoHansen's Avatar
BonzoHansen BonzoHansen is offline
And buttons on the side. I can't use my s8 because it has buttons on both sides. I used my old ipod instead
Scott from NJ
Old 05-13-2020, 06:10 AM
steve da wrench steve da wrench is offline
I did not see anywhere where you state what the part # is for the a Mann and Hummel Air oil separator. I looked on their website but did not find that particular one.
Also, who made all of the mods to the Peterson oil tank? Is this something we can purchase with all of the mods done to it, or was your own custom design & made thing?
Thanks for all of the great info. Saves the rest of us a ton of effort and wasted time and parts!
Old 02-26-2023, 03:42 PM
srode1 srode1 is offline
Looks like a ProVent 100. The 200 may have been a bit large for the location, it's pretty big. I am curious how the smaller one is working out.
Old 07-02-2021, 12:53 PM
Do you remember how you dealt with the 40 tooth reluctor ring requirement in the T56 magnum or if you used the Super Magnum with the 40 tooth ring installed? I have read some folks using HP tuner to adjust the 12 tooth ring that comes in the T56 to make it compatible with the GMPP controllers, just curious which route you ended up going.
Old 07-02-2021, 01:12 PM
randy randy is offline
Can’t just change the value to 12 tooth. Slight math involved. I’ve done 4 of them now this way. I have a post on here on what to do
