Old 04-03-2019, 05:55 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by OLDFLM View Post
Mark,
Can you address what was easy and what was difficult if anything?
ie. Old AC with new 5.3L?
Every looks like it just dropped in easily and fell into place!
Great job as always!!!
p.s. when do you want me to ship you my 2nd Gen F-body? LOL
The engine, trans and stock exhaust manifolds fit fine. I had to make custom engine mounts to position it where I wanted it. I think Holley sell mounts now. I just made my own because I knew it would fit.
The transmission mount was easy. I used the stock 78 Blazer transmission crossmember and mount and moved it back one set of holes. So far on the engine swap I had to drill two holes for the trans crossmember. The hot side of the exhaust the passenger side was stock and the drivers side needed reworked. I retained all the catalytic converters for cheap mufflers.
The Holley accessory drive fits great and solves the power steering pump issue that LT have.
The stock radiator went in very easy.
So far this has been one of the easiest projects I’ve ever done.
It’s been a lot of fun so far.
Mark
Stielow Engineering
Old 04-03-2019, 07:53 AM
vdrivinmike's Avatar
vdrivinmike vdrivinmike is offline
Awesome build! I love these Blazers.
Mike F
"ssmike" on PT.com
Old 04-03-2019, 08:40 AM
Musclerodz's Avatar
Mark
Thats because you didn't try to reinvent the wheel like we always try to do. Looks awesome, love the factory look. Are you going to try and hide a vintage air unit in there or retain the factory system?
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-03-2019, 10:51 AM
Stielow's Avatar
I intentionally looked for a Blazer with stock A/C to use it. I hope it works well converted to R134
Stielow Engineering
Old 04-03-2019, 12:23 PM
rstone rstone is offline
Default Ac
The stock AC is a little lacking. Chevorlet just used the truck ac in the blazer. lots more area in a blazer than a truck. i had an 84 blazer. always had to run it on max to get it cool.
Old 04-03-2019, 12:35 PM
Stielow's Avatar
Thanks good to know.
Stielow Engineering
Old 04-03-2019, 07:06 PM
jeff71 jeff71 is offline
Hey Mark, why factory AC over Vintage Air?
Old 04-04-2019, 02:47 AM
Stielow's Avatar
It came free in the truck.... Keeps with the factory look of the truck
Stielow Engineering
