Old 02-14-2026, 11:04 AM
Frankenstine's Avatar
Frankenstine Frankenstine is offline
Default Roller wheel question
Hi everyone. Hoping my 1969 Camaro becomes a Roller later this year. It will have Detroit Speed Hydro Subframe and Detroit Speed Quad link rear with Ford 9 inch . Thinking I seen where someone used some Dodge Charger/Challenger spare tires to make there’s a roller but can’t remember what year they used . Anyone remember the post or know if this will work ? Thanks
Old 02-14-2026, 01:31 PM
Depends on your bolt pattern. If it's still chevy 5 x 4.75" then the Mopar wheels would not work. If your axles and hubs have the Ford BC 5 x 4.5" they'd be right.
Frankenstine (02-15-2026)
Old 02-15-2026, 10:49 AM
Thanks Jody Been following your build. Looks awesome.
The Following User Says Thank You to Frankenstine For This Useful Post:
camcojb (02-15-2026)
Old 02-16-2026, 05:27 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
Yeah, I use them as rollers on pretty much everything. Anything 2005 and up are all pretty much the same and cost about $5-10 at the pull-it yards. I have slotted the lug openings (die grinder and about 2 minutes a wheel, and can fit them on anything from 4.75-5.5. Slotting the lug openings ruins it as a spare or driver, but they are just rollers.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
The Following 2 Users Say Thank You to CJD Automotive For This Useful Post:
camcojb (02-16-2026), Goosesdad (02-25-2026)
Old 02-16-2026, 06:28 PM
Yes sir thank you very much for the information, I’ll have to check some you pull it’s around here
Old 02-17-2026, 07:23 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
[IMG][/IMG]
[IMG][/IMG]
I used ones off of a 4th gen Camaro with a Morrison setup. Another option if you can find them.
Curtis
The Following 2 Users Say Thank You to Spiffav8 For This Useful Post:
camcojb (02-17-2026), Goosesdad (02-25-2026)
Old 02-18-2026, 01:10 PM
[IMG][/IMG]
[IMG][/IMG]
Ah okay always good to have options as I’ve heard the Dodge spare tires are hard to find. Thanks for the info.
camcojb (02-18-2026)
Old 02-18-2026, 02:51 PM
Spiffav8's Avatar
Lateral-g Moderator
Whatever you find that works, post it up!
Curtis
The Following User Says Thank You to Spiffav8 For This Useful Post:
Old 02-18-2026, 03:01 PM
[IMG][/IMG]
[IMG][/IMG]
What years are the ones you are using (in truck bed).?
Old 02-25-2026, 10:30 AM
Goosesdad's Avatar
Well, another instance of my dumb@ss not asking you guys for advice before spending $800 on Guni's.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
camcojb (02-26-2026)
