Old 03-22-2007, 09:57 PM
1971novaSS 1971novaSS is offline
Default 1971 Nova SS, G-Machine
New to the site. Just checking in with some info on my car and some pics. So here is the statistics on my car. This has allready been done or has been purchased and will be installed after i paint it in two or three weeks. I was just laid off from work so its time to tighten the belt a lil. It happens.
Factory Options:
This as far as i know is an original SS, I know it at least came with a V8 option. I did find bits and pieces of the build sheet but can't make out a damn thing on it due to the mice who drug it into the rocker panel on pass side to make a nest out of it. I have had this car for almost three years now and it has months until it is finished.
ONLY 2200 Miles on engine and Trans as it sits in car right now.
No miles on new suspension
Exterior Modifications:
Shaved door handles/locks. Shaved SS fender louvers(never liked them). But i will be keeping the SS hood louvers. It has 8 layers of primer/wet sanding done to it so far. And i am at the point where i need to perfect all the small details on the body before i paint it. The paint will be a Dark metalic Charcoal paint. With tinted windows to match the paint, i will not be blacking out the windows, but adequite tint. Shaved Nova emblems throughout the cars exterior, and possibly some led lighting. All new chrome on everything except the drip rail and window/door frames, i will be polishing them all. I have redone the SS louvers/grill/tail panel pieces to a brand new condition.
Replaced one quarterpanel and patched the other. New tail panel, new floorpan on drivers side. Fixed rust in corner of both doors. Smoothed the firewall. BASE/CLEAR on firewall and all pieces in engine compartment including suspension parts.
Interior Modifications:
Interior includes a customized dash with all auto-meter gauges, with gauge pod and hiden tranny temp gauge that flips down. New dash pad, carpet, bucket seats in front, with new door panels and custom rear interior pieces. Custom center consol. 4 6X9's with sony amp. CD player. New headliner.
Performance:
350 bored over .040
World Sportsman II heads(port and polished)
(TRW)Sealed Power 4v Flat top Hypertuetic pistons
Manley roller rockers/lifters with manley pushrods
Hastings Chromemoley piston rings
Clevette 77 berings
Competition camshaft,tappet lift 280 Degrees, lobe seperation is 110 degrees/ gross valve lift .480, Duration at .050 is/ intake 230/exhaust 230. Lobe lift .3200 at 106 intake centerline.
Patriot mid legnth ceramic coated headers, into 2.5 exhaust with 40 series flowmasters.
MSD 6A ignition with MSD billet aluminum distributor with MSD blaster 2 coil. With MSD 9 mm wires.
Pete jackson insainly noisy gear drive
Offenhauser Single plane, medium high rise intake with holley 750 double pump on top. With a holley blue electric fuel pump(set at 8psi) fed from a 20 gal aluminum fuel cell.
8 quart Canton racing oil pan with moroso deep sump oil pump.
Stock crank.
Suspension/Chassis:
Brand new poly-eurathane bushings all around, new ball joints, tie-rod ends. New SSBC brake system up front(sold old brake setup to pay for half of upgraded one : )
And disc brake setup out back from a 79 trans-am.
It has a CUSTOM 3-link rear suspension setup, i am going to install the CE 3-way adjustable coilovers for now until i have the extra cash for air ride. Rear panhard bar and sway bar. Front sway bar.
20X10's in rear with 295 30zr 20's toyo proxes 4
19X8's up front with 225 35zr 19's toyo proxes 4
Mini-Tubbed the rear to fit the bigger tires.
Drivetrain:
TRANS
Th350 with stage blue racing clutches and a stage three shift kit with titanium main gears(i believe thats what they said, i just told them to build it stout as *&%$) haha. Able to hold over 600 horse. Brand new built by Deans Automotive. Shifted with a B & M megashifter.
REAR END
Chevy 8.5 ten bolt.
Rear Discs, with new calipers, rotors and pads.
3.73 richmond gears with new posi clutches.
New T&T axels (new company from north idaho) Very stout and
good axels from what i hear and great quality as well as good price.
Electronics:
All wiring in the engine compartment has been hidden and tucked away. The coil has been hiden away as well. I have made my own wiring harness for my custom dash panel. And will be wiring custom LED's into the car soon. Along with an amp and 4 6X9's in the car with a CD player. I put in a double gauge pod on left of the dash as well. I have a hidden gauge which is in my dash that flips down to reveal it.
Here are the pics.
Let me know some input on what you guys think.
Old 03-22-2007, 10:03 PM
And some more pics. My previous post wouldn't let me put more then that. The first one is a computer rendering i did of a nova that was fetured in hot rod and is a member of this site. Hopefully he doesn't mind that i photo-chopped it to create my finish product.
Old 03-23-2007, 06:59 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Nice outline, should be a great car.
My LS7 69 Camaro
Old 03-23-2007, 07:34 AM
melman109's Avatar
melman109 melman109 is offline
Nice ride, keep us updated on the progress
Old 03-23-2007, 08:36 PM
pushrod243's Avatar
pushrod243 pushrod243 is offline
love the photoshop image. Looks cool so far. I thought about doing my dash like that too but with a piece of carbon fiber. Keep posting pics as you go together. Looks like it will be a great ride.
John
Old 03-23-2007, 10:41 PM
Thanks for all the comments guys. I will most definently keep ya updated. Will be having some pics of the 3-link i fabricated here pretty soon.
And as for the wood grain in the dash, It will be painted a textured special black paint. I just havn't got the innitiative up to tear it all back apart... Its a pain with big hands.
Old 03-24-2007, 12:56 AM
NOVA NOVA is online now
Get R Done! .... more Bad ass Nova's pleez!
Forgelines - Ridetech - DSE Tubs - ZZ4/700R
Old 03-24-2007, 02:16 AM
That rendering is friggin sweet! Makes me miss the 74 Nova I had in high school... we need more Novas to balance out the Camaros.
Old 03-24-2007, 02:58 PM
That would be the day that i perhaps have a heart attack!
And here are some more renderings of different colors. Im pretty fixed on that dark charcoal with black stripes.
Lil Lightening..... Lil Thunder......
Gun metal Gray, drak:
Lighter Gun metal Gray:
Flat Black:
Old 03-31-2007, 12:09 PM
71Nova 71Nova is offline
Looks cool and I like your screen name!! Wheels look great, nice ride height in the renderings. Great color choice. Welcome to the site.
David
