Old 05-03-2005, 05:37 AM
protouring70's Avatar
protouring70 protouring70 is offline
Default Pic's...
Here are some from my last car. I got mine from "Accessible Systems". But if you wanted to build one it wouldn't be hard if you had a welder. Also if anyone is interested in how "soda" blasting works one of the pic.s was taken after blasting.
Old 05-03-2005, 05:50 AM
ryans67deuce's Avatar
ryans67deuce ryans67deuce is offline
Another one available is the Roto 2000.
http://www.theroto2000.com/
I made mine with the help of my neighbor:
Ryan
Old 05-03-2005, 09:32 AM
61Bubbletop's Avatar
61Bubbletop 61Bubbletop is offline
Lateral-g Moderator
Here is the one we used on my car.....I don't remember the name,but the pictures may help with potential ideas if you decide to build one....
Old 05-03-2005, 12:57 PM
almcbri's Avatar
almcbri almcbri is offline
My father and I built the one for my car. Although I don't have any pics because my site is down. I used 2.5" oil pipe, although if I was going to build another I would go with square tubing. It worked well though. If you are going to build one make sure and add 2 locking points on each side and add grease certs so it will turn easier. I would recommend "locking" casters as well because you will probably move it around the shop from fabrication to body work and so on. I wish I had demensions of it. I had a guy come by last week to get demensions to build one for his 442. I had post over at PT or search some threads I know this is a subject that has been talked about and covered over there.
Andrew
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 05-03-2005, 04:37 PM
trapin's Avatar
trapin trapin is offline
Whatever you decide, make sure it has those hydraulic shocks on it. I've heard they are a God send.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 05-03-2005, 05:50 PM
907rs's Avatar
907rs 907rs is offline
Yes, You'll want hydraulic rams. I haven't bought any for mine yet, and it was a huge pain in the ass getting my car up high enough without them to rotate it.
Bill
Old 05-04-2005, 04:27 AM
rb70383 rb70383 is offline
Cool thanks for the info guys. Just to keep the fab skills up to date, I might venture into building one. I have checked on the 2 listed here. On the AccSytems, I think< they list a "balancer" including with all there bottoms up lifts. How did you all balance your cars on them? Trail and error, or anyone have a pic of that balancer? Thanks again.
