Old 04-13-2005, 12:22 PM
trapin's Avatar
trapin trapin is offline
I'm running Wilwood Dynalite Big Brake Front Hub's on the front and the Dynalite Pro Series with the rear parking brake on back. The calipers are 4 piston front and back. They'll be fed by a Hydroboost when I cross that bridge next year. I'm happy with the price and they look damn sexy on there too.
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 04-14-2005, 07:05 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
I just completed my hydroboost setup for my C4/13" front - rear drum setup. Now I have to retrain my brake foot.
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 04-14-2005, 10:36 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Originally Posted by Novacane
I don't have any room for a Hydraboost unit. The guys at Wilwood said it was not needed with a well designed 6 piston/4 piston setup. I would like to investigate the Alcons.....
I ran their four piston set up on my last project 1947 gmc pickup. They told me that I didn't need a brake booster and that manual would be more than enough but they were wrong because my truck stopped like crap.. Anyways to make a long story short I changed over to wilwood tandom master cylinder and matching brake peadal and that helped but not by much. On my camaro I'm running bear brakes 13" and 12" can't be more happy with it, but have to change over to hydroboost because not enough vacuum.
http://www.ridetech.com/projectview....e=KnownProject
Old 04-14-2005, 11:30 AM
rwhite692's Avatar
Best way I can explain how a Hydroboost system will improve the capability of a brake system....
Remember those SAT questions...Like:
Ball is to bat as nail is to:
A: CAT
B: HAMMER
C: STEAK
D: FOOTBALL
(ANSWER IS B)
Well,
HYDROBOOST is to BRAKE SYSTEM as NITROUS OXIDE is to:
A: DENTIST
B: INTERNAL COMBUSTION ENGINE
C: CLAM CHOWDER
D: PHONE BOOK
(ANSWER IS B)
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 04-15-2005, 12:26 AM
conekiller13's Avatar
conekiller13 conekiller13 is offline
Standard Baer package on My Chevelle. Worked awsome on the street and track. I repeatedly out braked Vetts, Porsches and BMW's. Never any fade problems. Of course I had only 300hp and a terminal front straight speed of around 130mph. I switched to a Willwood tandem brakes master with balance bar just before I took the car apart for the current rebuild. I'd really like to step up to some Extreme+ 14" rotors and Baers new 6 piston fron calipers. Gots to get bigger wheels though.
Old 04-29-2005, 05:54 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
Lets See
Fronts Brakes are 13" Corvette Drilles Slotted Zinc Plated Rotors with Custom Aluminum Rotor Hub and PBR Caliper on modified Stock Spindles.
Hawk HP Brake Pads
The Rears are 2000 Camaro Rear Disc Brakes with parking Brake and Drilled, slotted Zinc Plated Rotors.
Hawk HP Brake Pads
And Hydratech Hydro Boost System.
Oh yea In car adjustable Proportioning Valve for adjustments as fuel burns off.
David@RonsRaceShop
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
Old 05-03-2005, 01:20 AM
fbsideoiler427 fbsideoiler427 is offline
I let my brain engineer a brake package which borders on insanity but has been fun nonetheless. I'm running 15" rotors up front, 14's in the rear, E55 AMG front 8-piston calipers on all corners, Forgeline 19x13's in the rear and 19x12's in the front, DPI brake circulation system with external cooling.
67 Mustang FB
87 Buick GN
66 Kirkham w/FE
Old 05-03-2005, 08:29 AM
907rs's Avatar
907rs 907rs is offline
Sounds trick!! Got any pics?
Bill
Old 05-03-2005, 09:33 AM
What are You using for a master cylinder combination with those huge calipers all the way around? I think I have brake envy...............
Dan
Old 05-03-2005, 11:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Hell yeah, now that's insane.
My LS7 69 Camaro
