Old 04-09-2007, 12:43 PM
Default LSx adapter plates-are all same?
Are there any differences between ats,s&p,autocraft etc LSx adapter plates how close firewall they locate the engine? Or are all basicly just same ?
63 Z06
Old 04-09-2007, 01:24 PM
camcojb camcojb is online now
no, they aren't the same. ATS lowers the engine and sets it back in the chassis. I think Autocraft is similar. S&P is different and not sure about others.
Old 04-10-2007, 09:36 PM
Rubes Rubes is offline
All the ones I've seen (ATS included) use one of the 4 bolt LSx mounting holes for the bottom point of the 3 bolt old style motor mounts. This would indicate the front/back engine relationship would be the same, no? Also, ATS just mounts the old style motor mount upside down to lower the motor, and should be able to be done with any of the alternatives, from what I can see. BUT...the ATS is a really nice piece. I went real cheap and got some plain steel flame cut ones for $40 since my LSx project is just a throw together and NOT a show car.
Old 04-11-2007, 12:43 AM
Originally Posted by Rubes
ATS just mounts the old style motor mount upside down to lower the motor, and should be able to be done with any of the alternatives, from what I can see. .
This is what i was wondering too.
63 Z06
Old 04-14-2007, 10:31 PM
ss dave ss dave is offline
I have seen and tried the three above mentioned plates. In my 69 Camaro LS7 swap with stock front clip we ended up using ATS poly mounts with the Hooker plates, my Hooker Super Comp headers fit perfect without issues-once we moved the mount hats forward and down. Didn't have to dimple, grind or file. It also moved the heads a more comfortable distance from the firewall. ATS and Autocraft are the same, S&P has two different plates for different postions. My advice is to be prepared to experiment.
Old 05-14-2007, 10:27 PM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Default Ls6 in 1969 Chevelle
Does anyone know of any place that makes/sells motor mount adapters to put an LS motor in a 1969 Chevelle?
