Old 04-29-2007, 04:56 PM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
Default 6.0L LSx Cam. Piston/ Valve Clearance?
Has anyone got an idea about the max lift i can squeeze before needing to notch the pistons? I read many posts here and there on different combos and Man! These engines seem to be able to take over .600 without anyone mentionning notching from what i read!!!
I'm interested in about .630 and [email protected] for my application and am looking for information/ confirmation.
Thanks,
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 05-02-2007, 04:26 PM
Leadfoot1's Avatar
Come on guy's!
31 clicks and no one has an idea????
Nobody runs an LSx here!
'Guess i'll have to jump over to LS1tech....
Lead.
LEADFOOT1
Old 05-03-2007, 01:13 AM
pist0lpete pist0lpete is offline
What heads are you planning on running? I would say you are gonna be close on PTV(assuming stock 6.0 heads) with that cam you could go something more like a Comp 232/236 LSK lobe which should put in the lift range you want and make some killer power.
Old 05-05-2007, 04:03 PM
Leadfoot1's Avatar
Hey thanks Pete,
Yeah, at the moment i'm shooting for the stock heads.
I just ordered the intake (Vic Jr) headers (Hooker s-comp) oil pan and p-up (Moroso) + the mounts.
Next up are the w/pump, cam and some Nasty prformance Valve covers!
I'm also waiting on the T-56 to show up on tuesday.
Did you see the cam you reffered in a particular application, dyno or something?
I have seen a few interesting combos's... Just hard to know if the printing was legitimate...The errors that happen in some magazines are to be taken into consideration so i have my brakes on towards those things a little.
Lead.
LEADFOOT1
Old 05-15-2007, 01:15 PM
93Polo 93Polo is offline
It may fit, it depends on the valve events, and the heads used. I would check for your self the pistons may need to be flycut.
Lamar
69 Camaro RS traded
70 Chevelle SS 396
93 PoloGreen C4 LT1/ZF6 gone
00 FRC C5 436rwhp/415rwtq ported 5.3 heads/cam, MovIt Brembo Big Reds, 04 Z06 suspension
Old 06-04-2007, 08:51 PM
Zedzag's Avatar
Zedzag Zedzag is offline
I've got a crane 228/232 .600/.600 in my LQ4 6.0. I have the 317 aluminum heads which were milled .020 and no problems to report yet. She runs good.
Old 06-21-2007, 01:50 PM
Old Man Old Man is offline
I wouldn't go anything over a .600 lift on an LSX based engine without flycutting the pistons. The cam in my 408 is a 244/248 duration.612/.615 lift, my heads were milled .030 and we had to go with the relief cuts.
