Old 04-24-2007, 02:32 PM
buickfunnycar.com's Avatar
Default 1969 Z/28 12-bolt posi rear end for sale
68-year old friend has this for sale.Originally had 4.10 gears,has since been re-built with new ring & pinon gears (not 4.10) and re-done brake drum to brake drum.Numbers are as follows:
Casting date:E 258 (May 25,1968)
BV 0612G2 E
BV=12-bolt posi 4.10
06=June
12=12th day
G=Detroit Gear & Axle
2=2nd shift
E=Eaton positraction
Owner tells me the unit has less than 4500 miles on it and I have no reason to doubt him.He is asking $1,500 for it.Please contact me and I will put you in touch with the owner.Unit available for pickup in the Monterey Peninsula area,crating and shipment are the responsibility of the buyer.
*Update:Just talked to owner,this unit was purchased in '73-'74 from a local wrecking yard that was parting out a '69 Z/28.My dad (who owned a speedshop at the time) re-built it drum to drum in '75-'76 with 3.31 gears.
www.buickfunnycar.com
Old 04-24-2007, 05:35 PM
540 540 is offline
How much to get to Miami. Very Intrested were are you from. Please call Tirso at 305*322*2217
Old 04-24-2007, 08:05 PM
Monterey California Tirso...probably as far from Miami as you can get...almost.
Check your mail I PM'd you.
John
Old 05-14-2007, 01:09 PM
JackMonkey JackMonkey is offline
Is this rear still available?
Old 05-16-2007, 03:26 PM
Yes it is...sorry I don't check this section that much.
I did find out from the owner that the spring perches have been changed since this rear was in a '38 Chevy sedan.Whoever buys the unit will have to re-install the correct Camaro perches.
Here are some pictures I shot recently:
He was here showing me the axle the day before I shot these...guess we forgot to put it back the right way and it spun around on him...look at the damage to his wheelhousing...!
Freshened w/ARP bolts and all:
