Old 05-15-2007, 09:20 AM
rich-allen's Avatar
rich-allen rich-allen is offline
Default LS2 Head swap
I have two different sets of heads I'm considering. AFR mongoose or Trick Flow.
I have seen write ups on both (LS2 head swap CHP Mag) heads. TFS seem to be the better of the two but, they had some hand finish work prior to the test.
Any preferences for heads? also I will need new pushrods. Can anyone recommend a set and the length to use with those heads?
Thanks for the help.
Rich
Old 05-15-2007, 10:18 AM
rich-allen's Avatar
I talked to AFR, they recommended using crane pushrods and said stick with the stock rocker arms.
Any sponsors here that sell these heads?
Old 05-15-2007, 12:56 PM
PTAddict PTAddict is offline
Rich
AFR and TFS are both top choices (the others I'd put in that category are ET heads). You'll get some people over on LS1tech.com arguing strongly for their favorites, but in truth you're unlikely to see more than about 10 HP difference between them with all else being equal.
I have AFR 205s on my 5.7L LS1, with cam, headers, roller rockers, FAST 90MM intake, and it made 453 HP at the rear wheels with a conservative tune, and very mild idle and drivability. Tony Mamo at AFR has spent a bunch of time working out cams for various LSx combos with his heads, which is one advantage to working with them.
Old 05-15-2007, 02:17 PM
rich-allen's Avatar
Thanks for the reply, I ordered an exact duplicate of the cam Tony Mamo designed for an AFR head swap in a recent mag article.
The only problem I have with AFR is the 8-10 week waiting time for the heads. Summit can ship the TFS heads tomorrow. Some things are worth waiting for I just was hoping for some definite opinions.
Thanks again,
Rich
Old 05-15-2007, 11:50 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
I have the AFR 225 cc on my LS2.
I'm still far from getting it running and on the dyno.
Old 05-16-2007, 08:13 AM
rich-allen's Avatar
Found the AFR heads in stock at Scoggin Dickey.
Should be here by Friday. All I need now is the upgrade spring package and I'm ready.
Old 05-18-2007, 08:15 AM
Stang's Bane Stang's Bane is offline
Like was stated above, you will likely see less than a 10 rwhp difference between the 2 heads.
For my money you made the right choice, simply because of the rocker arm issue. TFS require the HS rocker arms and the AFR can reuse the stockers. However it would not be a bad idea to send the stockers to HS to have them perform their modification to them. $250 is really cheap insurance. AS far as the pushrods, after you get the heads in measure for pushrod length then. What were the specs on the cam you ordered?? Did you order the 225's or the 205"s. Either way, will be a nice setup
Old 05-18-2007, 09:32 AM
rich-allen's Avatar
I ordered the 205's and this is the cam specs:
GRIND # LS1 3725R/3726R HR114+2
DURATION @ .050
INTAKE 230 ROCKER ARM RATIO
VALVE ADJ INTAKE HYD DURATION @ .050 EXHAUST 232 INTAKE
1.70
VALVE ADJ EXHAUST HYD LOBE LIFT INTAKE .3480
EXHAUST 1.70
VALVE LIFT INTAKE .591 LOBE LIFT EXHAUST .3500
VALVE LIFT EXHAUST .595 LOBE SEPARATION 114.0
DURATION .006 INTAKE C/L
112.0
TAPPET LIFT INTAKE 279 ADVANCE 2
TAPPET LIFT EXHAUST 281
VALVE TIMING .050
VALVE OPEN INTAKE 3 JOURNAL DIAMETER STD
VALVE OPEN EXHAUST 52
VALVE CLOSED INTAKE 47
VALVE CLOSED EXHAUST 0
Old 05-18-2007, 10:03 AM
DURATION @ .050
1.70
EXHAUST 1.70
112.0
VALVE TIMING .050
You will be very happy with that combo. You have a big enough cam there to really provide a kick in the pants and the small runner heads will provide excellent part throttle response. I know you will enjoy it!!
