Old 05-24-2007, 05:15 PM
Originally Posted by XcYZ
I've been looking at the male fittings on my water pump for the heater core and I'd like to run AN if possible. I'm interested in what options I may have and/or what others have done with theirs.
mine isn't here right now, but they can be pulled out and can likely be tapped to 1/2" npt, 3/4" npt, or 1" npt threads to adapt the #12 AN lines.
Old 05-24-2007, 07:10 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool, I didn't realize that. How do you get them out without abusing the water pump, use a little heat?
My LS7 69 Camaro
Old 05-24-2007, 07:39 PM
I've always been able to grab them with vise grips/pliers and wiggle them back and forth without crushing them to remove. Wouldn't hurt to heat the pump casting right around the nipples to loosen them more. Shouldn't be tough to remove them.
Old 05-24-2007, 07:40 PM
XcYZ's Avatar
I know what I'll be doing tomorrow - borrowing a couple of big NPT taps from work.
My LS7 69 Camaro
Old 05-24-2007, 08:13 PM
you can do the legwork for me on this one. Let me know what size they are please!
Old 05-25-2007, 10:21 AM
We offer our water pumps on the Sidewinder with this already done. I'll get you the sizes you'll need, let me make a call....
Tyler
Old 05-25-2007, 11:53 AM
I chieseled mine out when pump was mounted on bench. Then the holes were welded shut and new ones were drilled and tapped to gain clearance on vette chassis.
http://www.bowtie-racing.com/cars/63...3z06engine.jpg
63 Z06
