Old 07-30-2007, 03:30 AM
deuce_454's Avatar
just one thing to keep in mind, the stainless steel is only stainless when exposed to air... if you cover it with paint.. it will rust if the paint chips and traps water in a low oxygen environment.. so it will last longer if left exposed
Jake: Hit it.
Old 07-30-2007, 05:06 AM
T Bell T Bell is offline
wow, I never knew that.
1972 Nova 355, 4 spd, rusty but something to drive.
1972 Pro-touring Cutlass S in the works....still
Old 07-30-2007, 04:59 PM
nova65ss nova65ss is offline
I have never heard anything like that either. I thought stainless didn't rust period? I know there are different grades of stainless and one in the 400's will get some splotchy rust over time. Hopefully since it will be garaged and not see alot of rainy days it will be ok. Thanks for the help,
Old 07-31-2007, 03:24 AM
deuce_454's Avatar
stainless is only stainless because the high chrome and nickel content forms an oxygen-tight oxide layer on top of the material when exposed to air.. if you look in a scrapyard at some stainless scrap covered in wet leaves or simmilar decomposing plant matreial.. you will find that the stainless corrodes under the wet leaves... "rusting" stainless looks black and very sad.. now on a showcar i am sure that a painted stainless fueltank will have a service life of several hundred years... so paint ahead.. but if you shoot it with somthing like rhino-liner and it lifts enough to trap water.. you could see corrosion
but to keep stainless uncorroded it should be left clean, and exposed to air.
Jake: Hit it.
Old 07-31-2007, 06:04 PM
JUSTANOVA JUSTANOVA is offline
i powder coated my rock valley stainless tank a satin black and i was going to polish the straps when i installed it but i havent gotten that far yet. I 'm not a huge fan of the "bling" either thats why i powdercoated mine.
Project EARTHQUAKE:
72 Nova SS, Plans have changed a little:artmorrison front subframe, and rear 3 link, pretty much stock ls1 and six speed with a single turbo for around 550hp. with a few other things mixed in.
current cruiser: "The green machine"
'70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct
and why do we modify everything...."BECAUSE STOCK SUCKS"
