Old 08-03-2007, 11:16 PM
slow4dr's Avatar
slow4dr slow4dr is offline
Thanks Paul! I've got some pretty big shoes to fill.
-J
'04 IS300 LS3/TR6060 swap in process
'89 Plymouth Colt GT - 411WHP, 2490lbs & 32mpg
'06 Magnum SRT8 - AFE S2, 3" Flowmaster catback, Diablo Predator (KIA by a drunk driver 10-25-13)
63 Nova 'Low Budget G-Machine' *SOLD*
Old 08-04-2007, 10:21 AM
zbugger's Avatar
zbugger zbugger is offline
Looks GREAT!! Doesn't look like it's gonna be fun though. Looks almost scary. Are you gonna leave the coil packs there? I doubt they'd handle the heat those turbo's are gonna be putting out.
Old 08-04-2007, 10:54 AM
novanutcase's Avatar
novanutcase novanutcase is offline
Good point!
Jason! You may want to think about fabbing a coil pack relocator so that the turbos don't fry them!
John
Old 08-04-2007, 11:06 AM
87wildside's Avatar
87wildside 87wildside is offline
Scary is fun! Looks good
My Build
Photobucket
Old 08-04-2007, 12:22 PM
slow4dr's Avatar
I've considered moving them but I am not sure just yet. The compressor side doesn't reach near the temps the turbine side does plus I am going to move the turbos back towards the firewall away from the coils. My SRT4 reaches EGT's in the 1700's and the hot side of the turbo is a mere inches from the factory coil pack. I hope that GM manufactured a decent enough coil to rival Dodge's reliability. I'll probably just make a little stainless heat shield for the coils for the time being.
Old 09-05-2007, 05:47 PM
slow4dr's Avatar
Well, it's been a long couple weeks and I haven't got much accomplished but here is where I am at. I mounted the I/C but I still need to make support brackets for the uprights. Each piece that gets placed in the compartment reminds me how cramped it's going to be.
Basic overview, BOV and cold pipe in place.
Running the hot side pipes are going to be interesting. I am planning on running them even with the downbars but just underneath which on the passenger side is no big deal, but I have a P/S pump to contend with on the drivers side.
This view shows how high I have the I/C mounted. The plan here is to split the incoming air in two. I am hoping to have a lower valence/air dam that will direct air under the I/C and onto the radiator. It's kind of hard to picture it without the front end mounted but imagine the very bottom of the current fiberglass even with the bottom of the frame heads. The air dam will extend another 4-5" below that and have it's own shrouding.
BTW: I have removed the coil packs for the time being until I can figure out exactly where the turbos are going to end up. I've experimented with the coils removed and the turbos mounted down low(where they're at in the pics) and up high with the coils in place and I like them better up high.
Old 09-08-2007, 12:46 AM
looks good wheres the front subframe from or did you make it.
Old 09-08-2007, 01:08 AM
race-rodz race-rodz is offline
i believe its C4 vette on his own rails.
Old 09-08-2007, 12:34 PM
slow4dr's Avatar
^^^^^yeah that
There are some pics in my signature
Old 10-16-2007, 11:26 AM
slow4dr's Avatar
I've had some pretty major changes both with the car and some personal things lately so I've sold all the turbo components. The twin turbo set-up will live on through another Nova guy.
Anyway, I've had a little time to start moching up the radiator and intake as well as redo the watts link. I have been shopping around for a C6 Corvette factory take off airbox/bellows/maf etc but I had some leftover 3.5" aluminum tubing so I'm just going to use it instead.
The 9" bars I was using on the watts link didn't allow enough suspension dropout to remove both wheels at the same time so I picked up some 12" bars and remounted it to the rearend.
HP tuners, headers, exhaust, fuel cell, fuel lines, radiator hoses, a few small items and the engine will be ready to run.
