Old 09-15-2007, 09:38 PM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Default Post #1 70 TA clone
Hi my name is John and I'm a car addict. I do almost all my own work with very little being done by anyone else. I've been working on this car since the early 90's and didn't really think of it as a G machine until Johnny Hunkins called it one when He picked it as Editors Choice at a NMCA race in Florida and wanted to do a photoshoot for PHR.
I use it for Street, drags, Road courses, Maxton (ECTA) and plan on some unlimited speed open road races eventually like the Silver State Classic. I have a couple different sets of wheels and tires as well as a few rear ends I swap in and out depending on the type of driving I'll be doing.
I've been checking out this site for a while but couldn't post due to technical difficulties.
John Paige
lab-14.com
Old 09-15-2007, 11:15 PM
DCreations DCreations is offline
Badass bird bro!!!!!!!!!! looks killer
Dave
“Tony Tony Tony, I know that your horny, but there’s
somethin bout that Bush ain’t right”
Old 09-15-2007, 11:20 PM
RussMS's Avatar
RussMS RussMS is offline
Nice Lookin Firebird. Could you give us some more specs and pics? We like the pics here.
Russ
Old 09-16-2007, 08:19 AM
NOT A TA's Avatar
Thanks guys! Here's the specs as well as I can remember them(been working on it at least 15 years).
Suspension & chassis
Hotchkis= Springs,Swaybars,offset upper control arm shaft,Bilstein shocks
Global West= Del-A-Lum bushings
Energy Suspension= Poly body mounts
Bolt in sub frame connectors
Moog and Spicer steering and front end parts
Stock Disc/drum brakes still with Raybestos rotors and Raybestos semi metalic Heavy Duty pads/shoes Ford DOT 3 heavy duty brake fluid (changed for every road track event) I think the Line Lock was a Hurst unit
I have 3 different 10 bolt rears,2.72 BOP(stock open) good for trips, 3.73 Chevy 8.2 with tightly sprung posi unit (drag use) and a 2.41 (corporate) posi with moser housings and tapered axles alloy cover etc for long road tracks, top speed events, and open road
Wheels and tires
Centerlines with 3.5's up front with Mickey Thompson ET Streets and Mickeys up front
Custom backspacing ARE TT II's 17 X 9.5 and 17 X 11 with Yokohama AO 32's 315 35's and 275 40's no body mods at all to get the 315's in without rubbing, fronts just touch the swaybar at full lock
Body
I did the bodywork and then painted it in my dirt driveway. It's not perfect but it still looks pretty good after 15 years or more. Orig TA body parts from about 10 different cars used to turn the original Esprit into the look it has today. The only aftermarket part is the center section of the front spoiler. Almost no part hasn't been modified in some manner. I need to modify the induction a little as it pushes the hood scoop into the hood even without the gasket and pushes the hood up a little throwing the side hood/fender gap askew a little.
Interior
Orig interior was red but I wanted black. I recovered the factory seats adding padding to the front buckets to bolster them and give them a little more "bucket" to keep me in place. Replaced carpet, headliner,dash,and package tray.. Schroth harnesses,B&M shifter, Auto gauge gauges in carbon fiber look dash panel,shift light in a factory Tic Toc Tach where the clock was. MOMO Millenium wheel on the way. 50 W AM FM cassette W/6x9's
75 PONTIAC 400 With '68 #16 heads MSD pro billet, coil,and 6 box. Performer intake with carb spacers and Speed Demon carb fed by Holley Blue pump. Canton road race oil pan W/Melling standard pump special pickup welded in place. Professional products damper, Flow Kooler water pump. Turbo 350 with B&M supercooler and shift kit. Will probably go 5-6 speed standard in near future.
John Paige
lab-14.com
Old 09-16-2007, 09:40 AM
907rs's Avatar
907rs 907rs is offline
Killer car. Welcome aboard!
Bill
Old 09-16-2007, 10:32 AM
NOT A TA's Avatar
m/albums/ff292/NOTATA/LimeRock.jpg[/IMG]
John Paige
lab-14.com
Old 09-16-2007, 10:48 AM
class67's Avatar
class67 class67 is offline
looks good! welcome.
Old 09-16-2007, 11:37 AM
holschen's Avatar
holschen holschen is offline
Default wooow
ehh damn nice car John
camaro69-l92+6l80e-
speedtech(LCA)-ats Street-Comp AFX-unisteer r&p-VariShock
camaro 5gen rear
Hydratech Brake Booster
movit brakes 380mm 6piston front- brembo 465mm 4piston rear
275/30-19 front-325/25-20 rear
19x9f 20x12r cray scorpions
Old 09-16-2007, 01:35 PM
almcbri's Avatar
almcbri almcbri is offline
I remember reading the article on your car. Nice car, glad to have you around the boards.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 09-16-2007, 05:42 PM
NOT A TA's Avatar
John Paige
lab-14.com
