Old 10-11-2007, 03:34 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Default Will these fit? 69 Camaro
18x10 7 3/8 bs
18x12 5.5 bs
DPE wheels GT7 series (two piece)
http://www.dpe-wheels.com/wheels.htm
I'm using a stock subframe and the rear will be mini tubbed. It's a good deal but I don't know if they will fit.
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 10-11-2007, 07:20 AM
camcojb camcojb is online now
Originally Posted by bigtyme1
18x10 7 3/8 bs
18x12 5.5 bs
the rears are fine depending on rear end length. I don't think the fronts have a chance with that width and amount of b.s. Sounds like they were made for an aftermarket clip with a wider track than a stock Camaro.
Old 10-11-2007, 07:30 AM
AllSpeedAndy AllSpeedAndy is offline
I'm with Jody, fronts won't work on stock sub, unless you're going with a wide body kit....other wise I wouldn't go any wider than 8"
Old 10-11-2007, 01:42 PM
bigtyme1's Avatar
Thanks Guys
69 RS Ragtop
[email protected]
Old 10-11-2007, 01:59 PM
the Wheels on the Rogue Camaro are
18x8 w/ 5" bs, front suspension is air ride strong arm with g-max spindles and it just clears the sub front to back, lock to lock and just...I mean just clears the tie rod enough to work.
19x11 w/6.5" bs , the housing is 57"'s axle face to axle face, minus the 1/4" rotor hats(57 1/2"'s total)...with DSE mini's, lots of room!! up or down with the bags.
