Old 10-13-2007, 03:31 PM
SteveMcqueenRules's Avatar
SteveMcqueenRules SteveMcqueenRules is offline
check out the latest issue of car craft there is a great article on this very topic with dyno testing proof.
You're gonna be hangin' on for mercy when I get this sucker rollin'- FALFA
Old 10-19-2007, 09:09 AM
6D9 6D9 is offline
Car Craft just did an article on 2.5" vs 3.0" exhaust this month. The motor was a 500HP 383 Chevy. Both systems were Flowmaster mandrel bent with Super 44 muffs. Peak for peak there was only a 3HP difference between the two systems. But in the mid range there was a 10hp/10tq gain at a few rpm points. So it at that power level if you have a really low car or dont want a bunch of noise the 2.5" mandrel system with high flow muffs can work really well.
Dang...you must of typed that right before me!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 10-19-2007, 04:06 PM
HILROD's Avatar
HILROD HILROD is offline
My Camaro has a 3in X pipe into 2.5 mufflers and tailpipes. This is with a supercharged 355. I've had fitment problems in the past, worse when mini-tubbed, with 3 inch tailpipes. I did a lot of searching before I bought anything. I think this is the best compromise. I don't think it gives up any noticible power. It's also quieter than full 3 inch systems. When I'm in boost that's a good thing.
