Old 11-01-2007, 10:16 AM
Blown353 Blown353 is offline
You can get the springs & hidden adjustable shims from Speedway Motors. You'll need the tall shims.
I run 750# up front and 200# 11" single pigtails out back. I might cut the front back to 650-700# but I need some better shocks first.
The 11" springs will get you quite low... you can see pics in my signature. But if you want them taller you can add shims. If you buy 12" springs and they're too high then you have to buy the 11" springs.
1969 Chevelle
