Old 12-05-2007, 12:43 PM
fesler's Avatar
fesler fesler is offline
Default Fesler Built new 1969 BB Camaro project update 4
Here are some shots of fixing some rust on the door and getting the firewall ready to be smoothed out. We do the car right we cut out any and all rust and weld in new metal for a rust free body.
Chris Fesler
Fesler Built - Scottsdale, AZ
Old 12-05-2007, 01:24 PM
fesler's Avatar
Default Fesler Built new 1969 BB Camaro project update 5
The Suspension, we removed all the factory suspension and installed the Air Ride Technologies upper and lower control arms up front with the Shock waves so we can get the car low.
Huge 6 piston Baer brakes all the way around
Chris Fesler
Old 12-05-2007, 01:31 PM
fesler's Avatar
Default Fesler Built new 1969 BB Camaro project update 6
19X10-inch FS901 Fesler wheels with black centers installed up front
6 Piston Baer brakes installed on the rear custom built Currie 9-inch rear end this car will be able to run a 13.5 wide rear tire if desiered.
Chris Fesler
Old 12-05-2007, 01:38 PM
fesler's Avatar
Default Fesler Built new 1969 BB Camaro project update 7
Tubs
The rear of the Camaro is pointless from the factory with the way the rear frame rails are installed any kind of horse power would bend them up so the best thing to do with them is to remove the factory ones and install some good ones that can handle horse power
So we cut out the stock rear frame rails and inner fenders so we can make some new ones that will fit the larger wheels
The rear frame rails will be moved over a bit as well to clear the larger wheels and then we will build some custom sub frame connectors so strengthen the under side of the car
Chris Fesler
Old 12-05-2007, 01:46 PM
fesler's Avatar
Default Fesler Built new 1969 BB Camaro project update 8
The Engine
for anyone wondering why we wanted to strenghten the underside of the car maybe this will answer your questions
GM Crate ZZ572 Deluxe engine
stats
620HP on pump gas
650FT
Forged Crank
Forged Pistons
Forged Rods
.623-inches of valve lift
Compression 9.6:1
Rocker arms Aluminum roller style
850CFM carb
Aluminum water pump
will run on 92 octane all day long
Add the Vintage Air Frunt Runner system and its good to go
Chris Fesler
Old 12-05-2007, 01:52 PM
slyck68 slyck68 is offline
We're not worthy! We're not worthy!
Old 12-05-2007, 03:15 PM
HRBS's Avatar
HRBS HRBS is offline
Holy Crap... Ben is right... this thing WILL be done by 7:37pm tonight !
Nice work Chris... always like the stuff you do. That green Chevy Truck at SEMA is one of my favorites !
HRBS on Facebook
Old 12-05-2007, 03:33 PM
buickfunnycar.com's Avatar
cool,thanks for the updates,can't wait to see the finished product!
www.buickfunnycar.com
Old 12-05-2007, 04:11 PM
jack67rs's Avatar
jack67rs jack67rs is offline
He had a really cool mustang fastback in bare sheetmetal at the Goodguys Southwest Nats last month. Really nice work!!
Tangerine 1967 camaro "Octane"
https://lateral-g.net/members/hodson/
Hot Rod cover Feb. 2008 "Homebuilt Hero"
Camaro Performers feature Car March 2008
Video on Webridestv.com
http://webridestv.com/showvideo.aspx?video=55306
Old 12-06-2007, 03:07 AM
redfire69's Avatar
572/620...couldn't you go bigger LOL!! Awesome picts of the build....
Question, does the lack of an X code denote a COPO. How so? (forgive my lack of knowledge)
Ron
Ron
69 Camaro Redfire
