Old 12-16-2007, 08:54 PM
parsonsj parsonsj is offline
Here's the current IAC vs Coolant Temp values. Look reasonable?
jp
John Parsons
Old 12-16-2007, 09:26 PM
jp
looks reasonable. How much have you bumped the cranking fuel in the colder areas?
Old 12-16-2007, 10:02 PM
The cranking fuel is up about 20% at 70, though it is closer to 15% at 85-90 degrees.
jp
John Parsons
Old 06-28-2008, 08:53 AM
sacarguy sacarguy is offline
Default ?
lower you iac at crank for cold temps and raise your low temp cranking fuel up ..
also is your pump wired up to prime when you key on or is it just constant after sitting for a decent amount of time without a priming pump this can happen as you lose fuel preasure in the rail.
leaning out
2 things
1 do you have the wide band setup so you are in closed loop .. your raising the fuel preasure and can be fatenting it up causing the ecu to start corecting the other way.
2 are you sure your fuel pump can handle the load of the higher preasure without losing a ton of volume.
Old 06-28-2008, 05:39 PM
leaning out
2 things
I think Mike Norris finally got the cold start figured out. And with my latest changes it starts faster than my truck! Amazing, but true.
But to answer your questions:
1. Yes, I have a priming sequence. At key "on" the pump primes for 10s, and I get fuel pressure after about 4s. I then start the car. It starts immediately now!
2. I'm using an Aeromotive A1000. I'm sure it can deal with volume at higher pressure.
3. I've got a wideband and run closed loop after the engine warms up.
jp
John Parsons
Old 12-16-2007, 10:13 PM
ohcbird's Avatar
ohcbird ohcbird is offline
JP-
what are your fuel #s during cranking? You might try closing the IAC a bit more for the same amount of fuel, then see what happens to idle quality & stability. How well does it transition from cold-warm-running temp?
IRT the leaning issue w/ greater pressure- was this open-loop, or closed? The injectors are supposed to be able to handle 75 PSI before overcoming the pintle or disc, so you should have seen a fattening, given all else being equal.
Old 12-16-2007, 10:20 PM
The car starts after about 6 seconds ... then nearly dies (or actually dies). Then I restart it, and it nearly dies ... then catches ... and then runs fine.
Listen to how the car starts. This video captures it very well:
https://www.youtube.com/watch?v=qAZPVNMh1SU
You don't have to watch the whole thing ... but that's what the car does when starting.
Yes, the leaning at 60 psi was very odd. It was at open loop. We did another experiment: we had the car hooked to the dyno A/F meter, started the car, and slowly increased fuel pressure. As fuel pressure went up, the mixture leaned out. 14.5, 15.0, 15.5, 16, etc.
jp
John Parsons
Old 12-16-2007, 10:22 PM
Cranking fuel (pulse width in ms) vs Coolant temp
20.1 ms 55 degrees
20.1 68 degrees
18.9 85 degrees
16.8 102 degrees
15.0 119 degrees
12.2 136 and up
Was that what you were asking?
John Parsons
Old 12-16-2007, 10:30 PM
ohcbird's Avatar
It still sounds to me that the IAC is cranked out to far- fattening it up might get it to catch a bit better. Can you see the IAC #s fluctuating while you're starting it, or does it stay static (slaved to the ECT)?
Still weird about the leaning issue!
Old 12-16-2007, 10:56 PM
I don't know. I think the thing to do next is log the IAC numbers and watch what the ECM does to get the motor to the target idle speed. That might be a clue to see what is going on.
About the leaning problem, something just occurred to me: I wonder if the issue was that we didn't change the fuel calc parameter for Injector Flow Rate. At 60 psi, the injectors flow more fuel right? So the number should have been more increased quite a bit ... maybe to 55 psi or something. Perhaps the ECM got confused, and was calculating the fuel load based on the smaller number? I can't quite wrap my mind around that (it's 2 am here on the East Coast, lol).
But I know we didn't change that value.
jp
John Parsons
