406 ci sbc, for sale. We built this motor for our shop car.
It is All brand new, never fired. The list of goods;
*Dart Little m block, 350 mains, ductile iron caps and o-ringed(all machine work Done by Steve Morris)
*4340 Eagle crank 3.750 storke
*Eagle 4340 H-beams with L-19 bolts
*Clevitte H-series bearings rods and mains
*JE Extreme duty dished pistons (-28cc's, #170818)
*Hell Fire rings
*Melling hv pump
*7 quart street/strip oil pan w/pick up
*Sfi ballancer (do not recall brand)
*Aluminum hv water pump
*March serp drive for alt, wp, and power steering (all included, type 2 gm
power steer pump)
*Dart Pro 1 heads #11710040, 230cc intake runners w/64 cc chambers
They have been fully polished runners and chambers.
*Copper head gaskets
*Ferrera severe duty Stainless intake valves
*Ferrera inconel exhaust valves
*Comp cams double with damper springs
*Comp retainers and locks
*Crane Cams rocker stud girdle
*Comp cams Pro Mag rockers 1:52 ratio
*Comp Cams custom grind solid roller cam.(turbo grind)
@ .015 lift 273/273, @.050-236/236
Gross lift @565/565 with 115
*Cloyes billet double roller set
*cloyes 2 piece timing cover w/adj cam button
*Motown efi single plane intake w/95# injectors and rails
with aeromotive return regulator #13110 pro series.
*All hardware and studs ARP
I'm sure I might have missed something...This motor was built to produce
well over 1200 hp with a pair of turbos on pump gas, as I said at the top it has never been fired and is all new, Any questions feel free to Ask!
Save big money! This complete set-up with everything for the Big Stuff 3 EFI is listed on EBAY! The listing is 250212272100. This is the perfect set-up for a nasty street car or race car. Everything is new!
