Old 01-24-2008, 06:01 PM
Supporting Vendor
We use whatever shim size it takes to get our measurements (normally 1-degree negative caster, 3-5-degrees camber). We've used shims up to 1/2" with no failures.
Old 01-24-2008, 06:25 PM
1/2" is about the most we were thinking (and have heard).
thanks
Old 01-25-2008, 03:15 AM
Your WAY off. First off fitting the 9 1/2 up front, good luck. But no matter what size you decide, on the front wheel, you need to deduct 3.25 or 3.00 inches from the wheel measurement to get your outside location correct. So in simple math, if you run a 8" wheel, you need a 4.75 to 5.00 backspace. If you run a 8.5" wheel, you need a 5.25 to 5.5 backspace. If you only want to go straight and not turn, usinf a 9.5 wheel, you would need a 6.25 to 6.5 backspace.
Frank Serafine
Old 01-25-2008, 10:21 AM
Well how come this 68 uses a 9.5" wheel with 275s up front with no issues? Carl C's website has been referenced many times on here and on pro-touring forum everytime someone asks or talks about stuffing a 275 up front. And judging from his pics, it tucks under the front fender pretty nicely and isn't sticking out. Can you explain this, and why I am any different? Thanks.
(go about 3/4 the way down the page to see "How to Swallow 275s on all 4 corners")
http://www.geocities.com/casanoc/
Old 01-26-2008, 06:25 PM
Frank?
Anyone else?
