Old 02-04-2008, 09:58 PM
tjbruning tjbruning is offline
diff mount should turn out great
Old 02-07-2008, 11:26 PM
ironworks's Avatar
Hay jim if your gonna change to poly bushings mock them up now they are wider then the stock rubber ones. I learned the hard way. The are pretty cheap and allow you to rebuild the used arms. The balljoints are easy to push out also to powder coat the arms. Or anodize.....
Rodger
Old 02-07-2008, 11:57 PM
novanutcase's Avatar
novanutcase novanutcase is offline
WOW!!!! Lot's of progress! Looking good Jim!
John
Old 02-08-2008, 10:39 AM
Rodger
Great info - Thanks ! I'll get them on order today before I weld up a mistake...
Old 02-08-2008, 11:44 AM
ironworks's Avatar
The uppers are more important then the lowers.
Old 02-08-2008, 01:17 PM
wow, after doing some research about types of bushings here - Vette Forum - and over on chevelles.com ..... I think I have brain stem swelling. Oh my aching brain pot.
Any other ideas folks ?
Energy Suspension
http://store.summitracing.com/partde...0&autoview=sku
Pfadt
http://www.pfadtracing.com/products/...&search=&page=
Vette Brakes
http://www.vbandp.com/detail.aspx?ID=770
Doesn't look like Global West makes stuff for the C5 system.
Old 02-08-2008, 05:56 PM
Exhaust hangar grommets came in today.
5$ per 4 grommets pack purchased from Street Rods by Michael.
Old 02-08-2008, 06:55 PM
ironworks's Avatar
The energy suspension ones do not come with inner sleeves and the stock ones are a pain to get out and the wrong size. Buy the others not the energy suspension ones.
Old 02-10-2008, 02:54 PM
Default What the ?
Looks like I'm going with the stock rubber bushings....
After 2 days of reading, there doesn't seem to be any consensus on any bushing type. A lot of discussions even had mixed types - Poly in upper and rubber in lower, etc.... cold flow, squeaking, binding, deflecting, deteriorating, grease – no grease, graphite – no graphite, too harsh -not harsh.
I guess I'll go with GM's research dollars and stay with the stock material. If it doesn’t work – I can spend the dollars later.
If I had gone poly - I would have chosen these:
Maybe the problem is I read too much. Just do it !
Old 02-10-2008, 03:38 PM
Default Fly By Wire
More parts coming in. This is from Ebay. Vette pedal assy.
I went to a car show this weekend here in IND and GM had a LS3 crate on display.... I can see how people get away from their budget. That is one awesome little package with a show price of 5K. That's very tempting.... Focus man - focus !
