Old 03-26-2008, 07:23 AM
GMracer's Avatar
GMracer GMracer is offline
Originally Posted by deuce_454 View Post
this could be done by setting the pieces of frame opposite eachother in a jig-- bridge the gap with 4 bent tubes in the corners of the rectangular frame... and "boxing" the structure bu adding the sides in flat stock.. that way when you grind the welds you will end up with a compound bent square tube with rounded corners and edges parallel to the OEM frame
didn't even see your post, that is a good idea, however I don't have a tube bender. I think Im going to do the pie cut, but add an internal plate on the face of it, it'll be trick to get in there and weld once it's closed up but I'm sure I could work something out. Maybe even add an external one too. Seems like the easiest way to go about this situation with the tools and experience I have.
Nick Schiffer
2001 Silverado Regular Cab Short Bed
Currently Under the Knife
Special Thanks to:
Air Ride Technologies - Wilwood Engineering
