Originally Posted by Smittys67
Yes they are for sale Im working on makeing them right now. They will be in the $2.50-$4.00 range with the bolt. The sizes will be 1/4 dia .700 .750 and they are .150 thick, 5/16 dia .750 .865 1.0 1.25 1.50 they are .200 thick, 3/8 dia 1.0 1.25 1.50. they are .250 thick. They are about the same thickness as the head of the bolts. If there are other sizes you want let me know im sure we can make them up.
Find a shop with a screw machine and you could really cut the cost with a bulk order. If you are doing them on a standard lathe or even a cnc turning center you are spending too much time. JM2Cents. You could keep the same margin and probably increase your sales numbers. There I go that manufacturing background is creeping out. It's just hard to swallow 2.50 - 4.00 per hole. Ouch!
They are very nice pieces by the way.
