first thing i did was lift the car and wire brush the entire underside to bare metal then paint the whole chasis in por-15 epoxie so no rust worries over time. then i flat blacked it all.
Looks good so far when you get that mod motor change or remove the egr on it ford uses a none vented one moisture builds up in it shorts out.The replacement one is vented.
