Old 04-06-2008, 05:27 PM
comp-spec's Avatar
comp-spec comp-spec is offline
Looking at were you are I would put the suspension back in and make it roller Setting on all 4 wheels
Then hang your doors, nose, quarters and trunk..get all the lines right then finish up the quarters. That way you will know what you have. You should do this mock up or you will be fighting lines and once the qrts are on they can't be moved
