Old 04-12-2008, 05:12 AM
Fluid Power's Avatar
I have thought about your first question and not sure I can come up with the correct answer. Same size tubing (ID) and smaller OD due to increased wall size....It might increase peddle pressure...Let me do some more research....I guess if you have extra, I would re-do the rear end in the same size and OD tubing.....Make sure to plumb in a bias adjuster.
Darren
