Old 04-15-2008, 07:48 AM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
Hear is what I made too mate the T56 to the pontiac motor.
Adapter.
Spacer.
Modified Bellhousing to clear the starter.
The abonimation of a cross member that I made and I will be remaking.
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 04-16-2008, 08:28 AM
Jimmy Sean's Avatar
Do you guys think I should grind the welds down on the back wheels that were widened or leave them?
Old 04-17-2008, 10:34 AM
72blackbird 72blackbird is offline
Jimmy,
Grinding the welds down may affect their strength- I'd mount a tire on the rim and see if it balances with the minimum required wheel weights. If it doesn't you may have to have a machine shop cut the welds down on a lathe.
Nice work on finding a low-cost 18" rim and low-cost solution to finding a 12" wide rim for the back. A '69 Bird and cute kids- what more could a guy ask for?
Geno
Old 04-21-2008, 02:54 PM
Jimmy Sean's Avatar
Small update, I continued to work on the mini-tub. Here are a few pictures of the progress.
Old 07-15-2008, 02:45 PM
Grambo90's Avatar
Grambo90 Grambo90 is offline
Hey Jimmy, I'm also in the process of building a 69 firebird and im looking to mate a t56 to a 350 pontiac block. So my question is what type of t56 do you have, a lt1 version or ls1? I might be able to buy a lt1 style t56 soon and was wondering if it would work with the modification that you did. Thanks
BTW... awesome bird
Joshua
69 Firebird
GEAUX TIGERS
Old 07-15-2008, 02:57 PM
Jimmy Sean's Avatar
BTW... awesome bird
Thanks!
I used the LS1 version for my build not sure what it would take to use the LT1 version.
