Old 04-20-2008, 02:03 PM
camcojb camcojb is online now
Originally Posted by Speedster View Post
Jody -
What amazes me most about your car is how you have taken 10lbs of "stuff", put it in a 5 lb bag and still make it look incredibly clean. I am sure looking up from down below is a maze, but from top down, you have pulled off a miracle.
You are going to have to publish your own 3 Volume Service Manual for that thing!!
that's a very good analogy Bruce; now with the intercooler and intake plumbing it's more like 15 pounds in a five pound sack...........
Old 04-20-2008, 05:14 PM
awr68's Avatar
awr68 awr68 is offline
Don't forget about the radiator hoses! Your IC has one in and one out right? That should be a little easier than 2 in & 2 out like you had planned for the Camaro.
Are the A/C lines already fabbed up?
Keep up the pace, you'll make it!
Tony
'68 Camaro
Old 04-20-2008, 05:38 PM
clill's Avatar
clill clill is offline
Jody...We are running short on time. You need to round up the usual suspects and have them help fab that 10lbs of stuff.
Old 04-20-2008, 06:13 PM
well, I started on the intercooler, air inlet, and radiator tubing today. Fabbed up the inlet first. Everything is just tacked as I have a guy who can copy my tacked together pieces and make it a one piece tube.
Then started the intercooler to throttle body. Very tight to get past the air inlet, turbo to intercooler hose, and lower radiator hose, but it clears.
Old 04-20-2008, 06:18 PM
Old 04-20-2008, 10:11 PM
67turbostang's Avatar
67turbostang 67turbostang is offline
Very nice Jody. That intercooler tubing looks like a tight fit, but its looking great. The Malibu keeps looking better and better. Keep up the good work
Old 04-20-2008, 11:06 PM
finished the intercooler to throttle body tubing (made it 2 piece as you cannot remove it as one piece), both radiator hoses, and the air inlets for both turbos. All that's left is the (2) turbo to intercooler lines, merging into one inlet; this will be the hardest part, so I saved it for last.............
Once finished I'll take all the individual lines I made and have them copied in stainless or steel as one-piece units, so no weld lines.
Old 04-20-2008, 11:10 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Not to be a broken record, but your car and attention to detail is awesome
Tom
Old 04-20-2008, 11:20 PM
thanks Tom. I've said it before, but detailing and neatness doesn't cost anything, just a bit of time and some forethought. Anybody can do it.
Old 04-21-2008, 12:28 AM
customcam's Avatar
an awsome street monster Jody
love it man
