Old 04-24-2008, 06:59 PM
OK, just picked up the piping after it was finish welded by a friend of mine, Warren at Midnight Performance in Rancho Cordova. I do all my dynoing at his shop. I originally built these pieces with the intention of having them copied in single pieces, but the compound angle and short distances between bends wouldn't allow most of them to be done as a single piece. That meant welding up what I had; since I can't operate my tig worth a darn I opted to let him weld them up for me.
The hardest piece was the crossover tube from the passenger side, merging with the drivers side into the intercooler inlet. I bought a merge collector and fitted the pieces up. Lots of cutting and really special angles..............
Here's the rest of the tubing. I'm going to final fit everything tonight and weld bracing brackets to a couple of the tubes that need it. Tomorrow they're off to the powdercoaters for titanium exhaust coating.
Old 04-24-2008, 07:55 PM
CRCRFT78's Avatar
CRCRFT78 CRCRFT78 is offline
Damn thats some nice work.
Old 04-24-2008, 08:55 PM
boonedog boonedog is offline
top notch as always
Old 04-25-2008, 04:58 AM
syborg tt's Avatar
Thanks Jody - now i'm late for work again
Your work looks great
marty-mj
Old 04-25-2008, 07:06 PM
ProTouring442's Avatar
I finished the fabbing of all the intercooler, air inlet, and radiator hard lines. I'll post some pics up when the final welding is done. Otherwise, progress isn't on stuff that would draw much interest as far as pics.
Frankly, everything about this car is interesting. Pics of pretty much any of it are always welcomed, as you are taking a sweet car and turning it into something amazing. For such things, we like to see as much of the work as possible!
Lookin' good!
Shiny Side Up!
Bill
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 04-25-2008, 09:44 PM
awr68's Avatar
awr68 awr68 is offline
Sweet! That's a big hurdle behind you!! What's next?
Tony
'68 Camaro
Old 04-26-2008, 08:24 PM
next, I sent the intake plumbing to be coated with titanium header coating. The color matches well with the car, but it sure scratches and scuffs easily. Might have to re-think that one later on. Big thanks to Steed at Perfect It powder coating in Rancho Cordova for helping me out, getting this back to me in one day.
Old 04-26-2008, 08:26 PM
added some new turbo heatshield bags. The other ones I had on there didn't fit well, these are much nicer.
added my heater hoses
Old 04-26-2008, 08:30 PM
had my headlight frames powdercoated. Changed the halogen bulbs for true HID's, with HID low and high beam on the one bulb. I don't think I'll even plug in the normal inside high beam as it won't match and the two outside lights will be plenty.
a quick pic of the air inlet tube. Has a little bracket that supports the end, from that small button-head allen screw just above the pipe. Filters are on order. Basically copied what Mark had in the car, seemed to work well.
Old 04-26-2008, 08:44 PM
zbugger's Avatar
zbugger zbugger is offline
It's looking awesome Jody!!! You're putting some great detail into it. I can't wait to get my car to that point.
Lost in a hopeless world on a path that wanders aimlessly and endlessly... As if it really even mattered.
