Old 05-14-2008, 03:39 AM
Travis77's Avatar
Travis77 Travis77 is offline
Default running fuel lines inside frame rails
Anyone hear try running their fuel lines inside the frame or subframe? It's not that big of a deal having them exposed, but it would be nice if they were hidden.
67 Fastback 418, hogans upper, FAST efi, Richmond 6spd, global west front, homebrew 3-link, mini tubbed, baer brakes with hydroboost, pilot sports on Ze Boost wheels
Old 05-14-2008, 06:47 AM
thedugan's Avatar
thedugan thedugan is offline
I'm quite sure they did that on Project Prodigy. Frank would have to chime in to confirm
Old 05-14-2008, 07:27 AM
mine is inside the frame up until it hits the firewall. It is a clean way to go, but pretty much requires a flexible line at least in my case, to get up and over the rear end part of the frame.
Old 05-14-2008, 09:53 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I have done this many of times. Make sure you use good line & fittings though. I have used bulkheads to exit the frame. Makes for a rela nice clean look. To this you will have to do some minor fabwork to make that happen cleanly - but in the end a much cleaner and safer way IMO. I have also done tranny lines and battery cables. Not a good idea though to run both fuel lines & battery cables together on the same side!! Not experience talking. Brakelines are the only ones I will not do. The should be supported well.
Brent
Old 05-14-2008, 11:44 AM
bentfab's Avatar
bentfab bentfab is offline
Hey Guys,
Saw the post and had to reply. I know everyone likes to hide things for the cleaner look but!!!! It is the worst thing you can do. Vibrations, chassis flex and all that good stuff that gos along with a moving machine causes ABBRASION!! In my experince of doing what I do I've seen hardline with at least an 1/8 wall thickness rubb rite through and cause a pin hole leak. So shoving soft line through areas that you don't know where a sharp edge is won't make for a good time when gas is flowing. The best way is to take your time make or buy nice clamps and route the line or hose properly. The most negleckted part of car builds are the last but most important. You can't GO or STOP with out properly routed fuel and brake systems Believe me I've seen it all!!! I hope this helps
Follow us on Instagram = @bentcustom
www.bentcustomandperformance.com
Old 05-14-2008, 12:37 PM
Travis77's Avatar
I can understand both sides here. I have straight 2x3 tubing for my rails. I was thinking of running .5" stainless tubing through the rails. AfterI ran the lines I considered drilling several .25" holes a few feet apart and injecting foam. I would think this might help with the vibration. By doing this though, I may defeat the purpose of running stainless. I say this, because I have heard that stainless needs to remain unpretected and free to an oxygen environment. But I would feel better running stainless rather anything else. Okay.... now I'm really .
Old 05-14-2008, 12:42 PM
Stang's Bane Stang's Bane is offline
Not true. I have run thousands of feet in the industrial enviroment and most of it was encased in a rubber jacketed insulation. The tubing will last longer than the rest of your car.
Old 05-14-2008, 01:09 PM
ironworks's Avatar
Why not run the fuel and brake lines inside the car next to the trans tunnel. If you do one solid piece and solidly mount it the only way to leak is if the line rubs a hole.
http://www.wallesdator.com/Foose%20d...g_4409_std.jpg
http://www.wallesdator.com/Foose%20d...g_4501_std.jpg
Rodger
Old 05-14-2008, 03:43 PM
bentfab's Avatar
Exactly if it rubs a hole? Also when you put the stainless through your frame and fill it with foam that foam might push the tubing up against the side and cause alittle friction and presto a leak!!! I'am just trying to let you know not to take your fuel and brake for granted. IT'S YOUR LIFE!!! Also Stang's Bane putting a band aid on something is'nt always the cure. I've used abrasion cloth from the industrial word just because I wanted extra insurance not to band aid a perticuler cosmetic issue. Besides I think two stainless steel polished or satin hard lines running parallel down a frame looks bitchen. Check out my web site and look at the Ranchero prime example of a box frame rail.
Hope this helps just my two & 1/2 cents.
Old 05-14-2008, 03:50 PM
ironworks's Avatar
I agree 100% nothing beats great plumbing and hardlines. I have never understood all these engine covers and such. Why not make everything look good, show the linkage and the hardline and the mechanics of the whole deal. But sometimes there is not room for everything on the frame rails.
