Old 07-01-2008, 07:31 PM
The WidowMaker's Avatar
well just in case someones reading this and missing the point, your 2 deg down needs to be from a properly aligned static setup. meaning if your pinion points 5 up, bring it down to 3. if its 2 down, take it down 2 more. you cant just set it at 2 degs down from whatever (level, the frame, the driveway) and call it good.
the 2 degs down allows for the pinion wrap up and will then make your dynamic specs the same as your static specs.
Tim
"The WidowMaker"
