					Originally Posted by  ProdigyCustoms
				We do a lot of these cars and sell multiple suspension packages. You do not have to spend big bucks to get a good 4 link system that works. I just copied your post and answered in bold.
I will be going with DSE Mini Tub kit, Global West full front Coilover setup, I would not do a coil over set up. There is not enough stored spring energy, and you are limited to lowering the car only 1 1/2" without shock damage.
DSE Smaller Tank, Looking to go with a 18" Wheel and 335 tires.
For a car that really wont be doing any autocrossing or even heavy duty handleing.....Would i be better off with a nice DSE Leaf/Coilover setup?  I would seriously consider a Chris Alston G Bar triangle 4 link. Not a ton of money ($1750), only a few bucks more then a leaf spring kit. Great ride, Great handling, easy installation, and no narrowed tank required. Just notch the corners of your tank for improved tailpipe clearance..
I just think spending an extra $3k for a 4link system for my car would be way overkill and that 3k can be used to buy for other things.  Agreed!
Feel free to call me and discuss your project 8AM to 10PM eastern time
four zero seven 832 1752
 Actually, ill be calling you about a Full Wilwood disc Brake Kit/setup! So maybe ill just buy a nice package from ya?
Also Does the 4 link that your talking about, work with a Mini Tub?
EDIT: I just wanted to add, my exhaust wont be going all the way to the back. So if that helps with the mini tubs and the 4 link i'll be ok.
