Old 09-10-2008, 01:57 PM
abadsvt's Avatar
abadsvt abadsvt is offline
Here is some pics of my tranny mount that i made.
Old 09-10-2008, 02:00 PM
abadsvt's Avatar
These last few pics for now are just other misc parts i got in. I am hoping to start building the headers today.
Old 09-10-2008, 02:17 PM
badmatt's Avatar
badmatt badmatt is offline
Looks awesome Josh!
97 Sonoma "NERA": Pile O Sh*t. Literally.
Old 09-10-2008, 02:24 PM
Beautiful work Josh !
Thanks for sharing your build.
Jim
Old 09-10-2008, 03:59 PM
ScotI ScotI is offline
Josh, that tank mount set-up is slick. One atta-boi for you!
Old 09-10-2008, 04:00 PM
byndbad914's Avatar
byndbad914 byndbad914 is offline
Originally Posted by abadsvt View Post
looks good from a fab perspective! I would only raise concern that you will fatigue fail at minimum if not stress fail the thin aluminum wall around the two rear-most bolts. The front bolts essentially act as an axial pivot point, which means all the weight of the fuel and external loading (like hitting a bump in the road inducing G loads on the fuel and tank) will have to be reacted through the two rear bolts. That loading *might* cause the aluminum to want to crack/break in the heat affected zone around that bung (I say *might* because you might be fine - I didn't do any math but just visually that is not the best idea)
FWIW - you can always simply try it and periodically keep an eye on the bungs and make sure you don't see cracking or leaking around them. But you will be surprised what kind of loads you can induce into a full fuel tank and I (honestly) have seen more than a few failed mounting schemes, but I have also been around a lot of racing which induces G-loading on a regular basis v. a cruiser like you are building. Typically you will see people build and weld in a very solid frame to drop it onto and then metal strap it into place.
Old 09-10-2008, 11:40 PM
abadsvt's Avatar
Hey Tim! Thanks for giving me your opinion. I really do appreciate it! I thought about what you just described but didn't think it would be an issue. I think i might take another look at it just to be sure cause i can always add another mounting point. Just trying to keep it simple and clean.
Thanks everyone else for the complements!
Old 09-11-2008, 07:33 PM
srh3trinity srh3trinity is offline
Nice build, this is my favorite body style Chevy truck. Nice X-15 in the background.
Old 09-11-2008, 07:38 PM
ironworks's Avatar
in my truck project we made the aluminum support go all the way across. Then we made to intersecting mounts from the rear. they go all the way across. to it only loads the tank aluminum in a vertical plane not a horizontal plane also. I believe there are some tank construction photos on my website.
Looking good, lets see some headers.
Old 09-11-2008, 08:26 PM
abadsvt's Avatar
So you ran the solid peices of alluminum all the way across? I am a little confused on what you meant "made the intersecting mounts from the rear? If i remake the sides and run a solid piece all the way across for my two mounting points (basically connecting the right side with the left side) that should help with the metal fatigue from all the loads? I looked at your truck build a bunch of times but you don't show any of the supports. I believe all you show is the basic layout of it when you first got it built.
I already started on the headers and I am loving it. So much fun and I really enjoy the creative challenges. I almost have the driver side mocked up so after i get that done i post some pics.
Josh
ps. those bent pieces line up great. I am not having to do much work to get it all to line up nice. Thanks for the help!
