Old 09-25-2008, 12:41 PM
rsk68's Avatar
rsk68 rsk68 is offline
Default Coil died!
so yesterday the car just stops dead, turns out the Coil failed, now this is a brand new MSD coil that cost me $50, it cant have 5 hours of run time on it, what do you think may have happened could it be just a freak part or could I have exposed it to to much heat, its mounted behind the carb on the intake.
does anyone have a sugestion for maybe a better model that would stand up to the heat, or should i mount it under the dash instead?
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 09-26-2008, 01:07 AM
class67's Avatar
class67 class67 is offline
I'd have to chalk that up to just being a bad coil, I think. Mine is installed in the same location as yours and I have not had any problems with it in 3 yrs.
Steve
67 Camaro RS
66 Chevelle (in progress)
