Old 10-26-2008, 05:07 PM
tmadden's Avatar
tmadden tmadden is offline
Default 9" on 67 Camaro
I bought a Ford 9" that is 53 1/4 flange to flange. Will it work? What kinda backspacing am I looking at? Please help!
Old 10-26-2008, 05:41 PM
axle flange to axle flange or housing flange to housing flange?
Frank Serafine
Old 10-26-2008, 06:16 PM
tmadden's Avatar
Default axle flange to axle flange I think
I think this is correct.
Old 10-27-2008, 10:58 AM
Stale67SS's Avatar
Stale67SS Stale67SS is offline
I have a new 9" from Moser Engineering with Wilwood disc brakes in my 67 Camaro. It's 60" wide (incl disc brakes ) and i run 9" wide wheels with 5.25" backspacing. If you know what offset the axels/brakes will give you, you can use this to figure your backspacing out.
Stale Feroy (Norway)
"If you're under control you're not going fast enough"
Old 10-27-2008, 03:32 PM
tmadden's Avatar
Default Thanks
The guys who are working my rear end gave me some numbers. hoping to order my brakes friday if I can get hold of Frank
Old 10-27-2008, 05:43 PM
Good Luck, LOL!
Best to call me and we can figure it out. I am available tonight. i have a tuner working on the car so i cannot get near it. OK to call me up till 12PM Eastern, we wont be going home before then tonight
Frank Serafine
