Closed Thread
Old 10-28-2008, 01:43 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Pete...stupid questions here but I'm learning a lot.
What's up with that rough edge?
Is that a sign of poor work?
In the sanding of the fenders I noticed a lot of different colors. Is that different product being used?
How much is normally on a good paint job?
Thanks in advance for the education.
Curtis
  #312
Old 10-28-2008, 02:26 PM
comp-spec's Avatar
comp-spec comp-spec is offline
The rough edge is were they welded to fix door gaps, very common with these cars and after market panels and some factory panels
The different colors are all different materials that were used.
Each job is different ...but a good job...... not that much
Maybe if you were doing an old 50 MERC in your backyard
Pete
Competition-Specialties.com
  #313
Old 10-28-2008, 03:08 PM
comp-spec's Avatar
here's the hood....
Pete
  #314
Old 10-28-2008, 03:09 PM
comp-spec's Avatar
Pete
  #315
Old 10-28-2008, 03:23 PM
syborg tt's Avatar
Looking Good Pete
marty-mj
  #316
Old 10-28-2008, 04:27 PM
z4me69 z4me69 is offline
it looks like he skim coated the whole car ummmmmm errrrrrrr 2 or 3 times and forgot to block it between coats . good thing you decided to strip the car but she's lookin good now
  #317
Old 10-28-2008, 04:45 PM
68protouring454's Avatar
pete nice work, let me know when you need the lid.
guys most high end cars get skim coated but his means 1/8 or under total thickness.
Jake's Rod Shop
  #318
Old 10-28-2008, 06:02 PM
mtlinvtns mtlinvtns is offline
Default recycle
Hey Pete the cars looking good now. To bad you couldn't reuse all that bondo dust, just add water, you wouldn't have to buy bondo for a year . How is the sheet metal? The panels look pretty good. Thanks, Jon.
jon sniger
metal innovations
171 Mattakeesett st. unit 8
Pembroke, Ma. 02359
1(508)212-4204
  #319
Old 10-28-2008, 06:39 PM
DRJDVM's '69's Avatar
Pete...what do you guys use to strip a car like this? Sanding disk, stripping disks etc......
It looks pretty good under all the bondo....
From everything I've seen ALL the top cars get skim coated in bondo and then blocked down until there isnt much left... but theres a big differerence in refining the shape vs sculpting the car...
  #320
Old 10-28-2008, 07:07 PM
comp-spec's Avatar
We used mostly 80 on a 8in stripping wheel for Tony's car.
Pete
Closed Thread
