Old 10-29-2008, 04:12 PM
sacarguy sacarguy is offline
Default 66 stang is moving along
first pics is of the grey high build polyester and guide coat waiting for block sanding
I can not say enough about this stuff its by spies and it is crazy its like sprayable bondo it goes on 4 mils thick per coat and spies says it can be 40 mils thick without any kind of issues such as cracking etc.
its so thick it takes a minimum 2.5 tip to spray it.
one coat blocked then a second coat blocked and the cars as flat as they come this stuff will literaly fill in a small hail dent with two thick coats and blocking its amazing the waves it will remove with two coats and blocking.
doing all the body work ourself behind my performance shop and having the final paint done by a pro painter I know will rent the booth and have him do the paint work then i will do the wet sanding reasembly etc etc.
Default hello
final eurethane 2k primer
will block sand with 220
then apply another coat and block sand with 320
then another coat and wet sand that with 600 then on to the final paint.
67 shelby style hood
whats that ? no drip rails shaved them and welded up and reshaped the edge.
shelby duck tail
Old 10-29-2008, 05:18 PM
love the early Mustangs.
Old 10-29-2008, 05:37 PM
awr68's Avatar
awr68 awr68 is offline
Looking great! I like all the body mods!!
Tony
'68 Camaro
Old 10-29-2008, 06:23 PM
65 347's Avatar
65 347 65 347 is offline
car looks great, making nice progress
Old 10-29-2008, 08:11 PM
Default doing what i can.
im doing all the metal work myself so its not going that fast but its moving along.
