Originally Posted by thedugan
As I worried. Oil sender wire is correct. I had oil pressure when I primed the motor. So something is up. Ugh
Gotta pull the distributor and see what's going on.
So gotta pull all the plugs again. Turn the motor to compression stroke and get it to TDC. Prime the motor and see what reading we get. Then re phase the distributor and rotor again.
or Ill mark the distributor and verify the collar setting and hope I can put it back in and fix the issue and keep the distributor synced.
when I adjust the slip collar distributors I adjust them without a gasket. Make sure they're all the way down with the drive in the oil pump, slide the collar down till it just meets the intake and then lock the collar down. That way when you add the gasket back in you have the free play needed so it's not bound up.
It sounds like possibly you didn't get the shaft engaged with the oil pump drive when you set the collar. Simple mistake, easy fix.
